Go to Post There should be no teams yelling "robot". - RoboMom [more]
Unread 03-08-2007, 08:14
Re: O/I POWER?
Originally Posted by popo308 View Post
Hey, another question would a computer power supply be able to power and o/i with the 12v out with 4.2 volts? would it be able to power 6 o/i's?
Brent,
Not sure what you are asking with the reference to 12 and 4.2 volts. Let's not forget that OI is powered from 12 volts through the tether cable. But before attempting anything like this, a prudent thing would be to call IFI tech support for help. In any wiring to multiple devices, steering diodes would be a nice addition to fused lined lines for each device.
Unread 03-08-2007, 16:00
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: O/I POWER?
Well the O/i's can handle up to 12vdc. right now we have 3 running at 12vdc at 1500Ma. A computer power source can do 4.2 amps. We need the amp power for running more than 3 and 4.2A should be plenty.
Unread 04-08-2007, 03:15
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: O/I POWER?
...4.2A should be plenty.
Technically each OI can draw up to 1000mA (1 amp!) at 12 volts.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 04-08-2007, 04:22
popo308's Avatar
AKA: Brent
Re: O/I POWER?
hmm interesting.... Well right now we have 3 running on a 12volt 2000Ma and there not cutting out or anything.
Unread 06-08-2007, 07:37
Re: O/I POWER?
Brent,
Keep this in the back of your head...Many computer power supplies need a minimum load current to turn on. If your power should fail at some point, it might be there is not enough current in the loads.
Unread 06-08-2007, 12:46
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: O/I POWER?
If you have access to one, I'd suggest an old (pre-ATX) power supply, as these use a simple on/off switch to turn on as opposed to having to short pins on the mobo connector.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 06-08-2007, 13:16
AdamHeard's Avatar
Lead Mentor
Re: O/I POWER?
Brent,
I've heard from our EE (Dale hall, used to post here) that a resistor or LED is usually sufficient load to achieve this.
Never tried it myself though.
Automatic Power Swampcoder2 Control System 6 03-02-2005 17:08
ROBO-POWER 12th-martyr General Forum 2 07-04-2004 18:02
OI power rocko Electrical 3 06-02-2004 19:30
Solar Power? dddriveman Electrical 26 26-06-2003 18:44
No Power UCGL_Guy General Forum 8 05-02-2002 15:54
