Go to Post Lexan $20.... Stock Aluminum $30.... Having a OI that is heavier than the robot PRICELESS.... - GBIT [more]
Unread 04-08-2007, 21:53
Leo's Avatar
Leo Leo is offline
FRC #0188 (Woburn Robotics)
Team Role: Student
Leo has a spectacular aura aboutLeo has a spectacular aura about
Plantery Gearbox Efficiency
I have been trying to design a drive train using the 12:1 plantery gearbox for the small CIMs, that way I can just adjust the speed a bit more with only one stage of chain/gear, which makes things really simple. I have a few concerns regarding the plantery gearbox, however.
1. What is the efficiency of the gearbox?
2. If efficiency is a problem, does lost efficiency come in the form of lost speed or torque?
3. And lastly, if it is lost torque, will I lose a pushing match against a robot geared to similar ratios, using same motors and wheels. Or, will I tie that pushing match (since my motor is at stall, no part of the transmission is moving, and it's just solid contacts everywhere )
Help please, and thanks in advance.
Fuel efficiency or home efficiency contest John Gutmann Technical Discussion 12 07-08-2007 21:59
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
code efficiency Anton Programming 4 13-02-2005 15:24
gearbox efficiency hi_im_sean Motors 1 26-01-2003 21:29
Motor efficiency archiver 2001 1 23-06-2002 23:30
