Go to Post In conclusion we will have a spaghetti game - Darkseer54 [more]
Unread 04-08-2007, 21:53
Leo's Avatar
Leo Leo is offline
FRC #0188 (Woburn Robotics)
Team Role: Student
Leo has a spectacular aura aboutLeo has a spectacular aura about
Plantery Gearbox Efficiency
I have been trying to design a drive train using the 12:1 plantery gearbox for the small CIMs, that way I can just adjust the speed a bit more with only one stage of chain/gear, which makes things really simple. I have a few concerns regarding the plantery gearbox, however.
1. What is the efficiency of the gearbox?
2. If efficiency is a problem, does lost efficiency come in the form of lost speed or torque?
3. And lastly, if it is lost torque, will I lose a pushing match against a robot geared to similar ratios, using same motors and wheels. Or, will I tie that pushing match (since my motor is at stall, no part of the transmission is moving, and it's just solid contacts everywhere )
Help please, and thanks in advance.
Unread 04-08-2007, 22:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Plantery Gearbox Efficiency
I believe the estimate is about 80-90% efficiency for those planetaries. Efficiency is typically considered as lost torque due to frictional losses in the gears meshing. As far as losing a pushing match.... That's dependent on FAR too many variables. If you're assuming the robots are exactly identical save for one having a more efficient gearbox... then yes, the less efficient one will lose. But there's so many other variables as to make that meaningless.
Unread 05-08-2007, 01:16
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Based on the efficiency of similar planetary gearboxes, I would guess the Banebots planetary to be around 90% efficient.
I don't think the difference in efficiency between the planetary and any other gearbox will be large enough to affect the outcome of your pushing matches. You really should be gearing your robot to slip the wheels rather than stall the drive motors anyway, in which case the efficiency of your transmissions will not matter.
Unread 05-08-2007, 09:13
Leo's Avatar
Leo Leo is offline
Team Role: Student
Thanks guys. I guess 80~90% isn't bad at all. That dispels all my worries.
Unread 05-08-2007, 14:21
AdamHeard's Avatar
Lead Mentor
I may be way off here..... but I think i'm quoting Dr. Joe Johnson here...
A planetary stage is about 85% efficient, so .85^2~ 72.
90% overall seems kind of fishy to me since that is the efficieny of a single spur gear reduction.
Unread 05-08-2007, 14:40
REVving up for a new season
FRC #2848 (All-sparks)
90% overall seems kind of fishy to me since that is the efficiency of a single spur gear reduction.
I would agree but spur gears are 90%~95% efficient if designed correctly. and with 2 stages in this transmission that puts the efficiency at 81-90%. This is using the standard method of multiplying the number of stages by the efficiency . But in a planetary since there are much points of contact per stage it is not entirely accurate.
now knowing the history of these transmissions and how poorly they are crafted and not taking into account the multiple contact points per stage I would suspect it would be at the bottom of that range close to 80%.
what we really need is for someone to take a cim motor and create a testing torque curve. Then mount that same cim motor in the tranny and test it again. We can then find out the true looses in the system.
Anyone got a torque cell lying around?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Fuel efficiency or home efficiency contest John Gutmann Technical Discussion 12 07-08-2007 21:59
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
code efficiency Anton Programming 4 13-02-2005 15:24
gearbox efficiency hi_im_sean Motors 1 26-01-2003 21:29
Motor efficiency archiver 2001 1 23-06-2002 23:30
