Go to Post FIRST robots definitely meet many commonly agreed upon definitions of robots. Some will disagree. Good for them. In my opinion, it's not worth arguing over. - Mikell Taylor [more]
Unread 05-08-2007, 21:54
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: pic: summer project coming along...
Originally Posted by joeweber View Post
Looks great. Looking at your vidio it looks like the pivot low for the handle will make it hard to ballance, if you could make it go forward and back with rotating handle grips that would alow you to lock down the lower pivot point making it easier to ballance it when you drive. With the drive set up it is going to be fast so hold on. check ours out at http://team1322.org/joeway.htm we used caster for ballance. Good luck. Looks like fun.
Joeway looks like a fun ride! And simple enough to be a nice offseason team-building project. How fast does it go?
The lower forward-back pivot is not a control feature on ours - it is just that the handlebar wasn't secured. The side-to-side pivot for steering is fairly rigid when its bolted together properly (which it isn't yet).
Latest videos (including what I would loosely define as balancing in the third one):
http://techtv.mit.edu/file/263
http://techtv.mit.edu/file/264
http://techtv.mit.edu/file/265
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
pic: Omnitrack Summer Project? Gabe Technical Discussion 27 07-09-2006 00:28
pic: Rage coming along TriggsJr Robot Showcase 4 14-02-2006 15:35
All-Time PID Drive with Hall-effects: Coming along very nicely jdong Programming 6 05-02-2005 19:39
summer coming... need job!!! btw, who's coming to Berkeley? archiver 2001 0 24-06-2002 03:46
How's everyones robot coming along??? archiver 2001 4 24-06-2002 00:01
