Re: Consolidating PWM's to one serial cable
from Ifi robotics
General Notes: 1. The red wire (center pin) on the PWM cable connected to the Victor is an open circuit. There is no reason to disconnect this wire in the cable. The Victor does not source or draw power on this line. |
| home-made pwm's? | darkorbit | Electrical | 2 | 17-02-2007 20:06 |
| usb to serial cable | karinka13 | Technical Discussion | 4 | 10-02-2006 17:30 |
| USB-Serial Cable + Terminal | Spencer E. | Programming | 3 | 22-01-2006 12:16 |
| Bluetooth serial cable replacement | seanwitte | Technical Discussion | 2 | 13-02-2004 17:25 |
| Serial Cable | Andrew Rudolph | Technical Discussion | 9 | 15-08-2002 22:09 |
