Go to Post To think that one can "learn" engineering in 6 weeks while under the strain of building a robot too is proposterous. FIRST isn't about teaching. It's about inspiring. - Collin Fultz [more]
Unread 08-08-2007, 03:02
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
default code
does anyone have a link to download default code... no cam
Unread 08-08-2007, 08:11
Re: default code
http://www.ifirobotics.com/rc.shtml#Programming
The 2007 RC Code link is near the end of the page.
Unread 08-08-2007, 16:45
popo308's Avatar
AKA: Brent
Re: default code
thanks
Unread 08-08-2007, 19:46
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: default code
And just incase you didn't already know
www.kevin.org/frc
has a ton of 'default' code for different things such as the camera, encoders, and a very easy to use serial port driver
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
