Go to Post "Magnificent" is the only appropriate adjective for a handlebar moustache. Kudos. - Lil' Lavery [more]
Unread 08-08-2007, 09:37
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Wii360... perfect example for RC?
Stumbled accross an incredible project this morning that interfaces a Wiimote & nunchuck into an Xbox 360. Basically it goes Wiimote -> Bluetooth into Laptop -> Outputs to project board through custom driver -> Project board with custom firmware -> PS2 gameport -> Adapter for 360 USB. He explains this insane project much better than I ever could, so here is the link: http://obsiv.spaces.live.com/Blog/cn...F394!177.entry
Essentially, a project like this could realistically allow you to control your bot with a Wiimote. Now, it might be impractical (have to carry around laptop; long development process), but its definitely possible.
Unread 08-08-2007, 13:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Wii360... perfect example for RC?
Apparently giving constructive criticism is no longer allowed on Chief Delphi...
Unread 08-08-2007, 13:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Controlling a robot with a Wiimote? It's been done.
http://www.youtube.com/watch?v=mj4lsNw3IG0
http://www.youtube.com/watch?v=0qEotHQgUsg
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-08-2007, 13:43
AdamHeard's Avatar
Lead Mentor
Originally Posted by Lil' Lavery View Post
What advantages would controlling your robot with a wiimote grant? It seems like an impractical solution that doesn't really offer any advantages over simpler solutions.
The driving of your robot (I assume) would be driven by the joystick on the nun-chuck, which would be virtually identical to driving your robot with a single joystick on an XBox/360, PS2/3, or PC controller.
I assume you'd use the motion sensing to control the robot's manipulator, probably most adaptable to an arm-type system. While it offers a different style of control and a more compact system than systems like this one, it doesn't seem like it would offer any greater levels of control or major advantages in speed or accuracy of your arm over similar control styles. While true, it is often hard to find a robot-centric control style for manipulators (rather than operator-centric), this solution is more complex than other possibilities (such as the earlier example, a touchscreen, or model arm).
I think you're entirely missing the point, don't lecture him on the impracticalities (he already admitted them).... It's just cool.
Unread 08-08-2007, 19:12
Kelly Kelly is offline
FRC #1418
Kelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud of
Why did remove your comment? It seemed perfectly reasonable to me.
Unread 08-08-2007, 19:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I received 4 negative reps from it, apparently most of CD doesn't feel the same way as you.
Unread 08-08-2007, 19:48
FRC #1418
So? They're just dots. It would be one thing if your comment had been truly inappropriate or unnecessarily rude, but you're just folding to peer pressure.
Unread 08-08-2007, 19:49
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Just to take the neg rep burden from Lil Lavery...
It's a cool project simply for its amazing ability to hack together many disparate elements, but I entirely agree with Lil-Lavery: Using a motion-sensing apparatus such as a wiimote to control your robot seems a bit counter-intuitive. I understand that there are teams that did it this year (one at GTR even made homemade wiimotes), and that is certainly innovative, but from my experiences playing my wii, I can't see a real fidelity advantage over other methods.
Since the accelerometers are the 2nd derivative of what you presumably want to measure (the position), then you've got to do lots of computationally intensive and potentially error-inducing integration to determine your position. Building a little model of your arm and tricking it out with potentiometers would allow for direct manipulation of your on-robot arm from your OI.
Sure you could use the accelerometers to infer the exact orientation of the remote (as many games do), but that can be tricked into innacuracy simply by the remote shaking a little (lateral or longitudinal acceleration would be misinterpreted as the remote rotating).
It would be an excellant off-season project to learn about custom circuits, programming, and about electronics in general, but I don't see any great advantage over more conventional methods.
Unread 08-08-2007, 20:24
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
yeah it was pretty cool some one from combots controlled there combot with a wii remote it got half way across the arena and lost signal so it wouldn't be a good idea to use in first unless u modified the remote and boost its signal
If it isn't broken, Fix it till it is ~ Baker
Unread 15-11-2007, 12:05
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Originally Posted by jgannon View Post
using it on a industrial robot and on the ones in first are two different kettles of fish. Provided it can be done logically with less gear and headache while conforming to the rules, the more articulated arms and turrets might get a boost and be competitive with the scale arm model I saw this past year.
The nunchuck is probably the more likely to have broad uses for turrets and launchers due to simplicity.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 16-11-2007, 11:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I don't believe arm control with a Wiimote would be stable at all. I played Wii Sports at a party a few weeks ago, and I was always crooked or off or shaky. Combine it with jumping up and down when you succeed at something and BAM you just hit the ref in the head. It would definitely take alot of practice and discipline to pull off.
For driver control, well, I played Descent 1/2/3 and could fly off of 3 axes at once using a single joystick -- it was sick and nothing but fun. All of those wierd hellical patterns you get from a spherical coordinate system? Yea I could fly those. I guess I'm a little biased there, but I will be stubborn and say that a single joystick is the best way to drive a robot.
On the other hand, with a hard-mounted WiiMote on your robot, you could get some serious sensor feedback control if the RC/OI would ever support it. I've already posted that idea here for future games.
GitHub
Unread 16-11-2007, 11:57
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Isn't there something about a positioned IR transmitter thats involved too? Or are we talking about using the accelerometers only?
Jacob
Example code TEAM1949 Programming 10 15-03-2006 16:00
PERFECT GAMES archiver 2001 1 24-06-2002 00:21
THE PERFECT MATCH and the PERFECT GAME? archiver 2001 10 24-06-2002 00:15
PERFECT WORLD archiver 1999 3 23-06-2002 22:20
perfect scores? archiver 1999 2 23-06-2002 22:10
