Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
Unread 10-08-2007, 00:18
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Interactive DashBoard
Originally Posted by lndnny View Post
This program looks great!
Too bad team 808 is out of first for good... but we aren't giving up.
We are doing a program called the national robotics challenge and entering a robot for a grand total of 30 some dollars. With none of the limitations of FIRST, we are actually going to try to send sensor output to a laptop and do all the long calculations there, but we're having problems doing this. Would you mind answering a few questions?
Was this program created in Visual Basic using the .net framework?
If it was, can you provide some source code or provide an example on how to read data into the visual basic program? - every time I try to read input from the serial port in my test program from the RC, I get question marks.
I'm using Kevin's serial port code to send data to the computer. Our team membership currently numbers four and we are all trying to learn as much as we can.
Thanks for your time.
Dan - former team 808
This program is written on .net, I believe its managed C++, but I'm not sure.
If you want to see how to use .net serial comm to communicate with the RC have a look at seanwitte's dashboard viewer. Its written in C#, but the implementation is very similar.
If you want help with .net serial comm, or .net in general feel free to PM me.
Eric Haskins KC9JVH
Interactive Debugger/Monitor duane Programming 10 11-10-2006 23:26
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
FIRST Interactive Rural SupporT coreyk FIRST Interactive Rural SupporT 1 12-11-2003 10:31
Interactive Map - Out of Date Don Knight General Forum 0 19-09-2002 17:54
interactive strategy piconysm Rules/Strategy 5 11-01-2002 08:47
