Go to Post When our arm "spontaneously combusted in the middle of the field", your team was the first to offer assistance to help fix it. - KTorak [more]
Unread 10-08-2007, 13:20
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
extracting code from robot
I know this is answered some where but i cant find it is it possible to extract the code from the robot if we don't have it any where else thanks
Unread 10-08-2007, 13:28
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: extracting code from robot
Unfortunately no, what is transfered to the robot is a form of the code translated into a language the Microcontroller understands. You could in theory disassemble a dump of the PIC and sort through it for the logic you used but you will never be able to reconstruct the code as you saw it in MPLAB.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 10-08-2007, 15:15
Device Reader Ver1.0.1 (found on the IFI FRC Robot Controller (RC) page) will allow you to retrieve the ones and zeroes from the RC, so you can save them somewhere and put them back later.
Getting from the compiled binary file to usable source code is likely to be a lot harder than rewriting the code from scratch, even if you don't know how to program and have to learn it in the process.
Unread 10-08-2007, 15:59
Jeff 801's Avatar
will this be the hex
Unread 10-08-2007, 16:53
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Yes
Unread 12-08-2007, 00:53
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
If, and this is a significant if, If jtdowney is correct in his assertion (good word, eh?) that the code is translated into a format designed for the Microcontroller, then NO, this will not be the hex. While it might be a reversible process, the logic would be way more complex - I've spent a lot of time (for my job) parsing text files, and even fairly simple formats have challenges involved.
So, again, if jtdowney is correct, then I don't believe Mr. Anderson's approach will give you the original hex file (though he would be the best person to ask about that). Whether the binary (which is of course easily convertible to a hex, if not THE hex that you put in originally) is helpful to you or not is up to you, though I would bet that it's not, unless you have a few months on your hands to write a parser. If you do, toss it out onto the GNU !
-Paul
Unread 12-08-2007, 06:23
Boiler Up
AKA: John Downey
The format for the microcontroller I was speaking of is the .hex. IIRC the C18 compiler takes the code and compiles it to a COF (common object format) file which is then linked into a .hex file. Since that is what you send to the RC you should be able to dump it from the RC using the tool Alan provided. That will allow you to get the current .hex file which you can save in case you ever need it again. The executable format the microcontroller uses probably has a disassembler somewhere if not the format is generally not to bad from my experience working with Linux ELF files. Once disassembled you will have the original code in assembly language which will show you the logic you used assuming you have someone who knows PIC18 assembly.
John Downey
Download code from robot Luminous Programming 4 25-05-2005 13:32
Recovering code from the RC Orborde Programming 15 04-12-2004 20:02
Extracting Individual bits in C Noah Programming 7 08-01-2004 15:53
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
