Go to Post Overpowered? You only took out half the building... Knock the rest down then get back to me. - sodizzle [more]
Unread 30-07-2007, 01:47
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
pic: summer project coming along...
Unread 30-07-2007, 01:49
AdamHeard's Avatar
Lead Mentor
Re: pic: summer project coming along...
Looking Good. Can't wait to see it finished!
Unread 30-07-2007, 03:01
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
That looks like an awesome summer project! I justed watched your short video clip and was wondering...why does the handlebar pivot in two dimensions? Shouldn't it only pivot left to right, and not also front to back? This is what it looked like in the last scene of the video.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 30-07-2007, 06:19
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
If you look at the video from 50 seconds, you will see that the handle is made to pivot left to right. As far as the end scene goes (pivoting front to back), I want to say that they haven't mounted the arm securely just yet.
It is a very cool project. Months ago, when Shane told me about this project, I knew that the students would pull this off. I am glad to see the outcome of the proposal for this project. Can't wait to see it fully functional. Good luck.
Unread 30-07-2007, 09:20
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
The bottom joint is for adjusting the angle of the handlebar or folding it completely flat, but it should be tightened firmly while riding, unless you want it try to surf it like in the video. As for the side-to-side motion, I would have settled for a twist grip or thumb joystick, but the high school students would have none of my compromises, so lean steering it is.
Thanks for the comments! It should be balancing in some fasion next week. (Although I say that every week.)
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 05-08-2007, 21:23
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Looks great. Looking at your vidio it looks like the pivot low for the handle will make it hard to ballance, if you could make it go forward and back with rotating handle grips that would alow you to lock down the lower pivot point making it easier to ballance it when you drive. With the drive set up it is going to be fast so hold on. check ours out at http://team1322.org/joeway.htm we used caster for ballance. Good luck. Looks like fun.
Unread 05-08-2007, 21:53
EricRobodox's Avatar
Happy Birthday! EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
joe, from first look, your scooter does not seem to be a segway style ride, in the sense of it being an inverted pendulum. The one they are making is, where its only 2 wheels total. That means no casters or anything else touching the ground for balance.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 05-08-2007, 21:54
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Joeway looks like a fun ride! And simple enough to be a nice offseason team-building project. How fast does it go?
The lower forward-back pivot is not a control feature on ours - it is just that the handlebar wasn't secured. The side-to-side pivot for steering is fairly rigid when its bolted together properly (which it isn't yet).
Latest videos (including what I would loosely define as balancing in the third one):
http://techtv.mit.edu/file/263
http://techtv.mit.edu/file/264
http://techtv.mit.edu/file/265
Unread 06-08-2007, 21:47
joeweber's Avatar
Coach team 1322
Watched your vidio, it looks great. I would like to see sombody on it (put a helmet on). We don't have the tech people to buld something like yours. I did see one like that at Huston stack attack many years ago that a guy built and his work alot like yours. Our used the fisher price motors and moved at a fast walk and tended to pull to the right a little. but was easy to build. We are currently working on a four wheel drive one that uses four small chip motors and is much faster. Check the bottom of our web page http://team1322.org/joeway.htm . Note ours is nothing like a segway thats why we call it a Joeway.
Unread 14-08-2007, 18:34
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
As of 8/11/2007:
http://techtv.mit.edu/file/272
I'd call it a Segway.
We also had some time to put together a spoof of Rockwell Automation's infamous video:
The Retro Encabulator
Unread 14-08-2007, 20:18
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
looks great. I have to say, the original Retro Encabulator video (which I have saved on this very computer) is one of my favorites, and that was an EXCELLENT spoof. Bravo and congratulations. Any chance it'll be making an appearance at the Boston regional this year?
Unread 15-08-2007, 09:58
Billfred's Avatar
Billfred Billfred is offline
Looks awesome.
Obligatory question: How are the BaneBots holding up?
Unread 15-08-2007, 12:30
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Undoubtedly.
So far, so good. There are still axial spacing issues, but those are well-known and easily fixed. As for the double-D, the 16:1 mod kits we got are in fact hardened to ~C30. Hopefully they'll hold up. If not, we've still got some tool steel left over... Not to excuse their flaws, but having a compact in-line gearbox was a HUGE plus for this project.
pic: Omnitrack Summer Project? Gabe Technical Discussion 27 07-09-2006 00:28
pic: Rage coming along TriggsJr Robot Showcase 4 14-02-2006 15:35
All-Time PID Drive with Hall-effects: Coming along very nicely jdong Programming 6 05-02-2005 19:39
summer coming... need job!!! btw, who's coming to Berkeley? archiver 2001 0 24-06-2002 03:46
How's everyones robot coming along??? archiver 2001 4 24-06-2002 00:01
