Go to Post The pen [may be] mightier than the sword, but the bandsaw can chop them both. - Marc P. [more]
Unread 14-08-2007, 09:40
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Drifting Gyro with EasyC
Okay, so the programming team was fiddling around with the KOP gyro last night for the first time using EasyC. We hooked up the gyro, and using the test code, were able to get a fairly accurate reading off of it, however, once we turned the gyro back to center, the reading started to drift. We were not turning it faster than the 80 degrees per second, and it still drifted pretty significantly (20 degrees or so) What do I need to do to calibrate the gyro with EasyC to prevent it for drifting like this?
Thanks
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 14-08-2007, 10:17
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Drifting Gyro with EasyC
If you are running the newest version you can adjust the deadband on the gyro by calling SetGyroDeadband() in the gyro function. Vibration will also cause drift. Default deadband is 3.
You can get the newest version at http://www.intelitekdownloads.com/easyCPRO
Unread 14-08-2007, 12:36
AKA: Malhon Godwin
I guess I said what wasn't working right. The gyro isn't in a way drifting. When you bring it back to zero, it increasingly is off each time as it passes its starting point ex. we started up the controller, and let the gyro initialize. slowly we moved the gyro about 90 degrees, and it was dead on. next, we brought it back to 0, and it was within a degree or so. Next, we rotated it 180 degrees, and it was within a bout 5-10 degrees. we then brought it back to 0, and it was off by about 20 degrees. Will the deadband take care of this? It is almost like it is not scaled correctly, but im not sure. Is there a way to change this in easyC?
Midwest Regional-
Unread 15-08-2007, 10:56
Kingofl337's Avatar
AKA: Adam
I'd still recommend playing with gyro deadband. You can write your own gyro function if you want to play with it. Just get the analog value GetAnalogInput() and average the samples and set that as your bias.
Subtract the Current Rate from the bias and the difference should be the rate of rotation.
Then it should be 12.5mv/deg sec.
I heard we got a 150deg/sec gyro this year is that true or was it an 80deg/sec again?
I think I might have a snippet of the gyro code around I'll see if I can find it.
Unread 15-08-2007, 12:02
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
I know that the gyro was a different one this year than last cause we couldn't simply change between the two without some very major changes to the code.
I will tell you that the gryo will slowly drift even when just sitting. We did some experiments in 2005 to see if we could get absolute positioning working with our swerve and found that it would get almost 45 degrees off with like 720 degrees of motion. Of course this was a drastically different gyro but we have found the same things to be true of both this years and last years gyro.
While I don't know if this is significant for a small bot I will tell you that it is meaningless noise for the operator of a FIRST bot. I barely notice when the gyro drifts because there are so many other factors that influence that bot.
Unread 15-08-2007, 12:15
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Did you consider using a MicroGyro? (datasheet) These are the same type of gyros as used in the Wiimote, and in the Gyration line of human interface devices for computers (wireless 'flying' mice).
They proveide a ton of accuracy, however I dont know how well they'll do in the harsh environment of a FIRST field... think the vibration might kill it, but who knows. I havent found a source for these yet but I'll look....
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 15-08-2007, 12:17
AKA: Malhon Godwin
Thanks for the help, I'll try tinkering with the deadband when I can get ahold of the gyro again.
Thanks
Malhon
Midwest Regional-
Drifting MattD1Drift Chit-Chat 30 22-03-2007 22:29
Problem with gyro... capenga Programming 21 16-02-2006 19:25
EasyC Timer and Gyro questions TubaMorg Programming 11 09-02-2006 21:19
Robot Drifting AsimC Programming 19 15-02-2004 21:49
