Go to Post Never underestimate people's ability to underestimate. - Ginger Power [more]
Unread 14-08-2007, 23:59
core2extremist2's Avatar
core2extremist2 core2extremist2 is offline
Progammer
FRC #1861 (Sharc)
core2extremist2 is an unknown quantity at this point
Exclamation running a basic stamp off of a joystick and a computer
i have a sg6 crustcrawler robotic arm with a basic stamp and a bord of educaton.
i am trying to get comand streems from the joystick into the comp and into degrese of a servo and out to the basic stamp.
im using a logitech wingman strikeforce 3d joystick
this is a usb joystick and the comand stream that comes from the joystick into the computer is unknone
so i would like to be able to decode that using a java program.
i have heard of direct x librarys for eclipse
-The Man Never Seen But Always His Programing Work Is Always Noticed-
MC
Unread 15-08-2007, 15:47
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: running a basic stamp off of a joystick and a computer
I made a program a few years ago in visual basic that allowed you to use a joystick as a mouse..
I used
http://allapi.mentalis.org/apilist/joyGetPos.shtml
and then you can just send the position or whatever out the serial port to be read by the basic stamp
Unread 15-08-2007, 19:21
Progammer
FRC #1861 (Sharc)
this doesnt help much because a mouse doesnt have as many butons as i need and this is a usb joystick
MC
Unread 17-08-2007, 18:24
Progammer
FRC #1861 (Sharc)
what i need to know about the joystick is these 2 things:
1. What data does the controller send back to the computer?
2. What format is that data in?
MC
Unread 17-08-2007, 21:51
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Um.. you can use any of the joystick buttons i just mapped a couple to mouse buttons.. and i was using a usb joystick
Unread 19-08-2007, 22:25
Progammer
FRC #1861 (Sharc)
ok i have the files what am i suposed to do with them??
i dont have visual basic
i have elcipse
MC
Unread 19-08-2007, 23:31
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Well they just provide examples of using the dll's. I dont know how easy it would be to port to c++ or java or whatever you are using but I just posted it as an example. btw, the code can be viewed by viewing the .vb file in notepad
Unread 20-08-2007, 00:25
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
GlovePIE is an application that maps input from (unusual) devices onto whatever else you want it to be mapped to. You can use Wiimotes to map to mice commands, joysticks to map to typing things, whatever. If it causes input, GlovePIE can intercept it and fake output as something else.
Combine this with a program called PPJoy, which allows you to create "ghost" or "software" joysticks that Windows think are real, and you can map whatever you want to a "plain old analog" joystick.
So, intrepid reader, you can now read a Wiimote into a computer and trick the computer into thinking it is whatever you want. Couple this with a bit of software, maybe a custom circuit or maybe just your serial port, and an FRC Controller, and what could you cook up?
A hundred thirty pound robot driven by a Wiimote.
This is on my to-do list for winter break.
PS, that whole wiimote thing is a tangent. Use GlovePIE and you can map the input joystick however you want.
Unread 20-08-2007, 19:13
Progammer
FRC #1861 (Sharc)
oh wow this is just what i need thanks
MC
STAMP (Statistical Team Analysis of Match Performance) is off and running! Ethulin Scouting 6 04-02-2006 23:12
Basic Stamp 2 and SSC Venkatesh Electrical 12 20-11-2004 21:57
BASIC Stamp as a server Raven_Writer Technical Discussion 7 23-09-2003 12:16
no basic stamp found! DLyons Programming 7 23-12-2002 22:17
Computer Graphics and Visual Basic Programing Gope General Forum 0 26-10-2002 13:44
