Go to Post Robotics = my anti drug. - Queen_of_Mascot [more]
Unread 16-08-2007, 22:48
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Water proofing a Project
First of all as an idea how about an off topic technical forum for random mechanical, electrical, and programming questions that have no relation to FIRST? LIke the Chit chat but pure technical threads.
Ok, my main point. The other night I was at a friends house when she was showing me the lighting in her pool so I had the idea of making little floating lighting elements. The problem is that I would like to make them totally submersible so you could just leave them in the rain and not worry about how you get them out. The problem is I want to be able to make them so that I can change the batteries in them. So it would need to be some type of box. I was thinking of maybe of just casting the actual control board or whatever I choose to do for the control (whether it be a micro controller or what) is some sort of non conductive resin but then I still have to worry about the battery. Then I though of using vacuum bags, but they are pricey, then I thought of the big sheets of laminate for text books but then how do I seal the box and what if water gets under the laminate?
Do you guys have any ideas?
-John
Unread 16-08-2007, 23:02
REVving up for a new season
FRC #2848 (All-sparks)
Re: Water proofing a Project
it is actually alot easier then you think. All you need is well placed gaskets and o-rings. There is a really good chapter in the machinists handbook on them, but the basic gist of things is you have 2 surfaces (like panel that comes off, and the plate it attaches to) and you cut a small groove (dimensioned to the size of the o-ring). When you put the 2 parts together it squishes the o-ring and creates a water proof seal. If you open most any electronics that are water resistant or proof you will see one of these. A good cheap example if you wanted to find one is a shower radio.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 16-08-2007, 23:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
there is a clear plastic food storage container you can get at Walmart (?) that has a rubber o ring in the lid, and latches to hold the lid on, brand name LOCK & LOCK maybe it would do the job.
Unread 16-08-2007, 23:26
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
This is the one you were talking about. We tested them and they're watertight up to at least 8 ft. (after smearing vaseline on the o-ring)
Unread 16-08-2007, 23:53
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
I advise caution using vaseline on the o-rings. I am not sure what material the o-ring is made of in these containers but vaseline is a petroleum product and will degrade some o-rings. There is a special silicone based o-ring grease made just for this purpose. Check a local dive shop and they will know what you are looking for. IIRC what we use at work is "Dow Corning 111".
Unread 17-08-2007, 00:35
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I forgot all about "tupper ware" type containers. I should just try buying some glad wear and putting a huge bead of silicone in the crease on the top if it isnt water proof right away.
-John
Unread 17-08-2007, 07:23
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
We use the same stuff at the dive shop that i work at we also use a a silicone product produced by trident diving accesories for $4.95 for a half oz. container witch will last you forever if you use it right. the product number is LP21.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Last edited by GBIT : 17-08-2007 at 07:27. Reason: i figured the product # would help.
Unread 17-08-2007, 11:22
Team 842 came up with a rather unique solution for their first entry in the underwater robotics championship. http://www.wired.com/wired/archive/13.04/robot.html
Unread 17-08-2007, 22:40
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
A good reference we use at work for o-ring seals is the Parker O-Ring Handbook. The Parker O-Ring Handbook goes over just about everything you would ever want to know about o-rings. Everything from materials and handling, applications, lubrication, groove sizes for various types of seals, o-ring profiles, etc, etc, etc.
Team 1538 / The Holy Cows, 2005-2016
Unread 21-08-2007, 19:20
Dick Linn's Avatar
no team (Synergy)
Those "lock and lock"containers are really nice! You could also investigate various PVC pipe fittings and cobble something together. Most of the plumbing stuff at my house is waterproof, LOL!
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 23-08-2007, 12:27
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
If you want something a little tougher than tupperware or whatever people are suggesting, get a small ammunition can from eBay or such, then build the light into that (anywhere on the box is fine really, so long as it can still latch shut). Then waterproof the light and the hole it's sitting in and you're good to go with a military ammo-can light-thing that you can still open up and work on and is perfectly waterproof.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 23-08-2007, 13:02
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
They did this on a recent episode of Hak5 if you are interested in watching a video of how they did it and how it turned out.
Unread 23-08-2007, 13:31
Otaku's Avatar
AKA: Michael Baker
I have no idea what Hak5 is, but if you can get me a video link, then by all means, please do.
-Otaku
Unread 24-08-2007, 00:59
Heavy Metal's Avatar
Heavy Metal Heavy Metal is offline
a world without music is true chaos
AKA: Nate
Heavy Metal is an unknown quantity at this point
y not just cut out a corner of a soccer ball fill in sides with metal to keep from folding in on itself and the cut out corner is the lid and you use superglue to make it waterproof just takes a lot to do it
one more thing
the see-through soccerball hasnt been made yet lol
My favorite online game http://runescape.com/
warning: vex may cause...
1.sleepless nights
2.anger issues
3.the possbility to go insane
plz build responsibly
(ironically webster defines vex as:
1.to bring trouble, distress, or agitation to
(this suggests stress and/or anger after hours of building vex)
[ECDU]:water Michael Leicht FIRST-related Organizations 4 15-08-2004 19:13
Water cooling? kc8nod Motors 12 08-02-2003 10:17
Water fights? archiver 2001 2 24-06-2002 03:07
FIRST water Jon K. General Forum 22 08-05-2002 19:50
