To you - I pledge my calculators, my codes, and my safety glasses. I'll be your Super Nerd forever!
Unread 18-08-2007, 14:45
Re: Mechanical/Electrical Off-Season Projects
I've been doing a little web research on bicycle frames and I now think that alum may not be the best choice for a bike that will see a lot of use and mileage. From what I have read, steel tubing has a threshold of stress (bending and twisting), below which you can literally stress it repeatedly forever and it will bend back (spring-like) and will never fail. Aluminum is not like that. Even a small bit of stress on an alum frame causes stress fatigue, and eventually it will simply break - and break completely with out warning.
Im not sure how correct that assesment is, because the mast and frame on my Hobiecat are aluminum, and the boat is 23 years old, and the mast bends noticably (intentionally) when you sail it. Maybe it will snap in half someday.
But I do know from working on FIRST robots that if you bend aluminum enough to deform it, you usually can only bend it back once, and the next time it bends it will fail. So Im thinking maybe chrome-moly steel tubing would be best for a custom recumbent frame. I would hate to put a lot of time and money into a custom frame and have something as simple as the wind blowing it off the kickstand causing possibly catastrophic damage.
It has also occurred to me there is another easy way to make a long frame recumbent bike frame. I made the one I have now, the way I did, because I wasnt sure where the pedals and seat would end up, but now I could build something similar by extending a standard diamond frame by about two feet. If you cut the top tube and extend it with a straight steel tube, and miter cut the tube from the pedals to the fork head, and extend it to match the new angle, you would have a frame with the same dimensions of the bike I have now. All you need to do then is weld the pedal cluster up in the new location, and add the underseat handlebars, and seatback.
I photoshopped this to see what it will look like. Check in the HMLAT directory on my aol ftp site for bridgestone.jpg and bridgestoneA.jpg to get an idea of what Im talking about. If I were to build a second bike like the one I have now, I think that is the way I would go (if I didnt build a whole frame from scratch).
One thing I have not found a good solution for: making a long frame recumbent adjustable for differnet size people. If you move the seat forward and back you need to move the understeat steering too. The other option would be to make the pedal cluster position adjustable, but then you need to take up the chain slack somehow. I dont have a solution in mind for either approach. So far my bike plans led you to a bike specifically designed for one person. Anyone else who is not the same height would have a difficult time riding it.
Mechanical Vs Electrical D.J. Fluck General Forum 28 30-04-2007 15:59
Off-season projects: What are your teams working on? AdamHeard General Forum 10 19-07-2006 12:36
Awesome website for off season side project antics. Cool projects too. Elgin Clock General Forum 7 07-07-2006 12:54
Off-Season Projects zdeswarte Off-Season Events 6 23-02-2005 16:31
Off season projects JamesCH95 General Forum 17 13-12-2004 23:32
