Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 19-08-2007, 01:46
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: 114 New Gearbox Design
Originally Posted by 114ManualLabor View Post
Interesting. I'm still seeing higher torque on the 3 inch CIM... However, I'm emailing the source for the numbers I've been using, as to find out where they came from. Here they are, in case anyone cares:
----------------FP801-005 3.0" CIM---------FP801-001 2.5" CIM
Torque---------200in-oz--------------------100in-oz
Power----------245 W----------------------250 W
Efficiency-------59%------------------------45%
Current Draw----34A------------------------37A
Shaft speed-----1650 rpm-------------------3800 rpm
Again, not sure where this comes from, but I'm investigating that right now.
Those numbers are totally wrong. The document Dave mentioned has the correct specs. I've never seen these before.
2001-2004: Team 100
2006-Present: Team 254
pic: 114 2 speed Gearbox CraigHickman Technical Discussion 13 25-02-2007 19:41
pic: 114 Gearbox CAD CraigHickman Extra Discussion 7 26-01-2007 23:37
pic: 1881 new gearbox design GMAdan Extra Discussion 7 21-12-2006 01:59
pic: 114 drive module design CraigHickman Extra Discussion 3 06-12-2006 21:59
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
