#16
Re: pic: 114 New Gearbox Design
Thanks, Pavan. |
#18
Motor "fighting" can be explained in one word: nonexistent. It comes up a lot in FIRST, I don't know why. It simply is not true. As long as the motors are spinning in the same direction, they are both contributing useful torque to the cause. Now, if you have two different motors geared together, their load sharing may vary over a range of speed, but they will easily strike a happy medium. While you will not end up with the full torque of each motor added, you will have significantly more torque than just one of the motors. The efficiency of the system is likely to drop a bit though.
#19
Looks a lot like our gearboxes from this year for our mecanum drive. haha. Spur gears were 20.5PA 24Pitch and so they're hiding behind.
Are you using big cim to save money on gears? If it's for weight, it wouldn't really help. The weight for a gearbox using a small cim motor and same final speeds will end up probably in the same ball park. But using two big cims in the whole drive, heaviest motors nice and down low, would allow the small cims to be used elsewhere up higher. But running at equal speeds, the small cim is more powerful than the big cim. I can't find the spreadsheet I used, but I remember that it was a decent loss, around 20-30 ftlbs, although when it really came down to it, it was traction limited. How much torque will the gearboxes be outputting before stall? Last edited by Jeff K. : 20-08-2007 at 02:23. |
#20
Are you still intent on using just the Big CIM?
Also, you mention Outback manufacturing. Is this THE gearbox they will sell? If it is, it definately needs to support 2 motors and be able to use small CIMs to stay competitive on the market. I'm still baffled by the choice though.... One small CIM is more power for half the weight (remember, the motor can draw 133 amps [at stall] and the electrical system WILL supply it for a short time. It doesn't just hit 40 and stop), two small CIMs is double the power for the same weight. Also, One big CIM geared to 9 fps takes a little over 1.5 seconds to reach top speed... For 9 fps, that acceleration is rather slow. Why not design it for One Small CIM and one Large? That leaves open two small CIMs for manipulators like you desired, and still provides a competitive level of power. |
#21
That'd be pretty interesting, if you could get one gearbox on either end. Probably break a lot of belts though. Having both on one end would need some decent displacing by a battery. |
#22
i would love to see these worked into the outbaack treads, and I'm sure Sam would also love to see this, were you planning on having 2 per side or just 1?
I know that running the two motors into 1 transmission actually cuts down on efficiency... thinking those treads could push any harder is sorta mind blowing, awesome design :-) |
#24
Either way, two decent drive motors (small/big CIM, FP) will be more powerful than any single motor. |
#25
But when it comes to any 2 DC motors you can't get them to be exactly the same. Even if they are the same model so there will be some efficiency loss. However it is insignificant so it really doesn't matter.
#26
uhm.... just wondering, but why are you calculating everything out based on one point along the motor's torque curve? Personally, I just find a spot that makes me happy (and the Victor drive happy) and use that as my torque numbers at that rated speed.... then i rate my top speed at just rolling friction, etc, watching what current i'm at, etc....
I RapidShare'd the torque specs for the 2.5" cim. I'll see if i can dig up my copy of the 3" cim torque curve. Post with ?'s or //s. -q |
#27
To make this whole process easier, I just use JVN's design calculator. Go under the simulator section, enter your motor specs and the robot stats (wheel size, friction, weight, etc...) and it will provide some wonderful graphs about the performance of your drivetrain. It can also do a bunch of other cool things. Check it out if you're ever designing ANYTHING on a FIRST robot that has a motor and reduction; it will help immensely. Thanks JVN |
#28
-q |
#29
nice!
| pic: 114 2 speed Gearbox | CraigHickman | Technical Discussion | 13 | 25-02-2007 19:41 |
| pic: 114 Gearbox CAD | CraigHickman | Extra Discussion | 7 | 26-01-2007 23:37 |
| pic: 1881 new gearbox design | GMAdan | Extra Discussion | 7 | 21-12-2006 01:59 |
| pic: 114 drive module design | CraigHickman | Extra Discussion | 3 | 06-12-2006 21:59 |
| pic: 114 gearbox design | CraigHickman | Extra Discussion | 4 | 05-12-2006 19:53 |
