Go to Post That sounds like PONG. For you youngsters, that was the first video game available for the public to play. - Robert Cawthon [more]
Unread 19-08-2007, 22:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: 114 New Gearbox Design
Originally Posted by M. Krass View Post
These are the performance statistics for the motors at or near 40A, not at stall or at free speed.
Also, though at 40A the larger CIM is producing more torque, it's moving much slower while doing so, as others have mentioned. A better indication of which motor is "more powerful" is to look at, as you might guess, the power. The smaller CIM has a power of 250W -- more than that of its larger cousin.
At any rate, the 40 amp breakers don't trip at 40A anyways--it's significantly higher for a short period of time, so the torque would increase as well.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-08-2007, 23:08
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Originally Posted by 114ManualLabor View Post
Also, only having one motor eliminates the issue of torque fighting when there are two motors on a gearbox.
I am slowly trying to learn something other than controls, and I am having trouble understanding this "torque fighting" you are speaking of. Could somebody explain this phenomena to me?
Thanks,
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 20-08-2007, 00:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Thanks,
Pavan.
Motor "fighting" can be explained in one word: nonexistent. It comes up a lot in FIRST, I don't know why. It simply is not true. As long as the motors are spinning in the same direction, they are both contributing useful torque to the cause. Now, if you have two different motors geared together, their load sharing may vary over a range of speed, but they will easily strike a happy medium. While you will not end up with the full torque of each motor added, you will have significantly more torque than just one of the motors. The efficiency of the system is likely to drop a bit though.
Unread 20-08-2007, 01:57
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Looks a lot like our gearboxes from this year for our mecanum drive. haha. Spur gears were 20.5PA 24Pitch and so they're hiding behind.
Are you using big cim to save money on gears? If it's for weight, it wouldn't really help. The weight for a gearbox using a small cim motor and same final speeds will end up probably in the same ball park. But using two big cims in the whole drive, heaviest motors nice and down low, would allow the small cims to be used elsewhere up higher. But running at equal speeds, the small cim is more powerful than the big cim. I can't find the spreadsheet I used, but I remember that it was a decent loss, around 20-30 ftlbs, although when it really came down to it, it was traction limited. How much torque will the gearboxes be outputting before stall?
Unread 20-08-2007, 02:32
AdamHeard's Avatar
Lead Mentor
Are you still intent on using just the Big CIM?
Also, you mention Outback manufacturing. Is this THE gearbox they will sell? If it is, it definately needs to support 2 motors and be able to use small CIMs to stay competitive on the market.
I'm still baffled by the choice though.... One small CIM is more power for half the weight (remember, the motor can draw 133 amps [at stall] and the electrical system WILL supply it for a short time. It doesn't just hit 40 and stop), two small CIMs is double the power for the same weight.
Also, One big CIM geared to 9 fps takes a little over 1.5 seconds to reach top speed... For 9 fps, that acceleration is rather slow.
Why not design it for One Small CIM and one Large? That leaves open two small CIMs for manipulators like you desired, and still provides a competitive level of power.
Unread 20-08-2007, 02:40
Jeff K.'s Avatar
Hmm..now what?
That'd be pretty interesting, if you could get one gearbox on either end. Probably break a lot of belts though. Having both on one end would need some decent displacing by a battery.
Unread 20-08-2007, 10:55
CraigHickman
Posts: n/a
This isn't THE gearbox, it's simply one of maybe three designs we're looking at. I was asked to design a single Big CIM gearbox, and so it was designed. An upcoming field test between two drive systems with equal speed but different motor choice should reveal which motor will end up better.
Unread 22-08-2007, 14:30
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
i would love to see these worked into the outbaack treads, and I'm sure Sam would also love to see this, were you planning on having 2 per side or just 1?
I know that running the two motors into 1 transmission actually cuts down on efficiency... thinking those treads could push any harder is sorta mind blowing,
awesome design :-)
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 22-08-2007, 16:41
AdamHeard's Avatar
Lead Mentor
awesome design :-)
Running two of the same motor has no inefficiency. Running two different motors (at matched speeds) have some, but it can be minimized by close matching.
Either way, two decent drive motors (small/big CIM, FP) will be more powerful than any single motor.
Unread 22-08-2007, 17:32
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
But when it comes to any 2 DC motors you can't get them to be exactly the same. Even if they are the same model so there will be some efficiency loss. However it is insignificant so it really doesn't matter.
Unread 26-08-2007, 20:57
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
uhm.... just wondering, but why are you calculating everything out based on one point along the motor's torque curve? Personally, I just find a spot that makes me happy (and the Victor drive happy) and use that as my torque numbers at that rated speed.... then i rate my top speed at just rolling friction, etc, watching what current i'm at, etc....
I RapidShare'd the torque specs for the 2.5" cim. I'll see if i can dig up my copy of the 3" cim torque curve. Post with ?'s or //s.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 26-08-2007, 21:18
AdamHeard's Avatar
Lead Mentor
-q
Hmmm...
To make this whole process easier, I just use JVN's design calculator. Go under the simulator section, enter your motor specs and the robot stats (wheel size, friction, weight, etc...) and it will provide some wonderful graphs about the performance of your drivetrain.
It can also do a bunch of other cool things.
Check it out if you're ever designing ANYTHING on a FIRST robot that has a motor and reduction; it will help immensely.
Thanks JVN
Unread 27-08-2007, 11:46
AKA: Alex
Hmmm...
Thanks JVN
Neato, thanks! Now i have to figure out how to keep the guys in the robotics club (guys learining how to build robots) from finding this....
-q
Unread 27-08-2007, 13:42
AdamHeard's Avatar
Lead Mentor
-q
Don't thank me, Thank JVN.... I keep hearing around here that he's a dweeb... but he makes some cool stuff
Unread 11-09-2007, 21:44
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
nice!
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
pic: 114 2 speed Gearbox CraigHickman Technical Discussion 13 25-02-2007 19:41
pic: 114 Gearbox CAD CraigHickman Extra Discussion 7 26-01-2007 23:37
pic: 1881 new gearbox design GMAdan Extra Discussion 7 21-12-2006 01:59
pic: 114 drive module design CraigHickman Extra Discussion 3 06-12-2006 21:59
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
