Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 08-20-2007, 11:57 PM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: External power for LED worklights?
I just had a thought. Perhaps instead of making repair/maintenance areas more easily visible, maybe focus on making the robot more reliable and less likely to need repair and maintenance.
Unread 08-21-2007, 11:31 AM
I like this a lot. As far as I am concerned, the quality of an electronic device is directly proportional to the number of blinky lights on it. Safety / Visibility is good too.
Unread 08-21-2007, 04:27 PM
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Put more LED's inside the robot.....Our 2008 robot is going to light up like a Xmas tree!
Unread 08-21-2007, 08:51 PM
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
It happens, man. I've only ridden in a robot's frame ONCE (and I was driving too), and that 2 minute ride has really helped me understand why random stuff seems to break.
Unread 08-23-2007, 12:11 PM
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
That's actually a really good idea (especially for those robots that have stacked electronics or small, closed spaces), and I'm sure teams could justify the cost and time to build such a thing.
Even if your team does build it though, don't forget to bring flashlghts anyways just in case the light system fails (but assuming the person knows how to solder and knows their positive leads from their negative leads, it shouldn't) or you need to look in a dark spot somewhere else (under something in the shop, for instance).
I'm thinking I should talk to my team's electrical guy and see what we can come up with, though. I'ts a cool idea.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Power suppy for dashboard. lancerbotics Technical Discussion 10 05-03-2007 11:52 AM
External Lens for optical mouse gnormhurst Electrical 4 01-07-2005 07:07 PM
New LED Lights this Year, spec for placement? Chris_Elston General Forum 12 02-16-2004 05:32 PM
External Spotlights Brandon Martus CD Forum Support 17 12-04-2003 09:38 PM
Battery power for OI? P.J. Baker Technical Discussion 6 06-21-2001 02:46 PM
