servo PWM sampling-what Fosc should I use?
Hi.
my goal is to sample a servo pulse from an R/C receiver, and I'm not sure what XTAL to use, I mean, what is the minimum Fosc I should use? if a 4MHz = 1MHz internal clock, so with a 1:1 prescaler I should get 1 sample every 1 mS. if I'm correct, a servo's pulse is between 0.9mS and 2.1 mS, meaning I need something quicker, am I correct? will a 20MHz XTAL be the answer? thanks, Ran. |
| What program should I use for website design? | radioshackkid | Website Design/Showcase | 35 | 03-02-2007 22:12 |
| Trying to use a new servo | team1500 | Electrical | 1 | 20-02-2006 21:27 |
| What size breaker should I use for the RC? | Excelsior | Electrical | 4 | 18-01-2006 07:34 |
| Did you use Auto Servo Mode? | Greg Marra | Programming | 8 | 27-04-2005 15:35 |
| What Motors Should I Use? | dddriveman | Motors | 20 | 16-07-2003 21:19 |
