Go to Post Don't test your autonomous on the comp field. There's a practice field for a reason. - DampRobot [more]
Unread 23-08-2007, 11:51
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: FIRST Inventor lib?
Originally Posted by Billfred View Post
I imagine that if you've got some KOP or other common robot part that Ed Sparks (same name here on CD) doesn't have, he'd be up for uploading it.
Actually as I understand it, Ed does not generaly upload parts from others. He wants the parts in the library to be RIGHT. So he only uploads parts he has measured and modeled himself.
This might sound like a pain, but I can think of one year we used an "off-brand" model of a Fisher-Price gearbox to design our robot. It turned out that the models were slightly off from the real parts. We figured this out because we couldn't install the gearboxes without cutting apart and re-welding the frame. The frame members we were using for mounts were too close together, even though the model showed clearance. We measured and found the frame was built according to plan but the FP models were off.
Fixing it by reworking the frame would have taken time we didn't want to spend and would have required re-designing other subsystems. The "easy" way out was to change the manipulator design concept and build a custom 1000:1 gearbox, in two weeks. We took the easy way
I appreciated Ed's approach a lot more after that.
Christopher H Husmann, PE
"Who is John Galt?"
Inventor 2008 // last thread EVER about chains in Inventor? Dan Zollman Inventor 10 10-07-2007 20:01
help with clib.lib nirvanapunk1015 Programming 1 10-02-2007 10:46
WHERE IS ifi_library.lib ?? LieAfterLie Programming 0 02-02-2007 17:53
**FIRST EMAIL**/Autodesk Inventor Training Update! Pat Fairbank FIRST E-Mail Blast Archive 0 10-11-2005 18:37
Team 103 FIRST Inventor Submission JasJ002 Inventor 7 08-04-2005 13:26
