Re: MIT/FIRST DIY Segway
I'm amazed they got enough power at a reasonable current with 12volts... I think the segway runs like 48 or 96 volts to cut down on current/wiring weight.
Anyone know what motors they used? PWM drives? (Being MIT, they probably put their own FET bridges together) As a note... i'm not sure you could build this with the current FRC control system... the 120Hz max chop rate on the victors would probably make your servoing relatively rough (Segway probably has an update/chop rate of several KHz) Amazing project... now if I could just pitch having to build one to my boss so I had the funds.... -q |
| DIY open exhaust | Mike | Chit-Chat | 3 | 06-06-2007 22:57 |
| DIY auto gauges for your computer!! | John Gutmann | Chit-Chat | 1 | 02-06-2007 12:50 |
| DIY water cooling | Morenoh149 | Chit-Chat | 2 | 28-02-2006 23:44 |
| DIY Active Noise Cancellation | phrontist | Technical Discussion | 20 | 28-08-2004 07:45 |
| Robot Rivals on the DIY network | sanddrag | Televised Robotics | 1 | 07-11-2003 22:49 |
