Go to Post Its Mario Kart with balls and really, whats more fun and frustrating (FIRST style) than Mario Kart? - Adama [more]
Unread 24-08-2007, 14:57
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: Air Cannon
Well, we never got it approved through the school, we just did it.
I win! XD
Unread 24-08-2007, 17:58
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Re: Air Cannon
Psch, your guys' cannon is dangerous. The high school from IRI has a few new holes in its ceiling
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 24-08-2007, 20:21
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: Air Cannon
Our school hasn't forced us to do a safety run. We just talked to the athletic director and he thought it was cool. Before the first game, he may require some demos though.
As for proving it's safe, I'd say do some test fires, maybe have people catching them up in the bleachers, prove they aren't getting hurt.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 25-08-2007, 00:23
artdutra04's Avatar
VEX Robotics Engineer
Re: Air Cannon
Is any part of it made out of PVC? If so, you may want to look into shielding it (in case of rupture) or using higher-PSI rated fittings. (PVC, though often labeled on the pipe itself as able to hold enough PSI to be considered "safe", is never supposed to be used for any sort of pressure application.)
Replacing the PVC with safer alternatives, such as air hoses and metal fittings rated for high pressure gas use with sufficient PSI rating (including a safety factor), would be a smart idea.
Art Dutra IV
世上无难事,只怕有心人.
Unread 25-08-2007, 01:27
Back in the Game
AKA: Ed Venator
FRC #2399
Re: Air Cannon
No PVC is used for stored pressure (that's in a craftsman pressure tank).
The barrel and a couple of fittings are PVC, but these will never be under high pressure as the barrel is open.
(Any further questions, comments criticisms, PM Mike Nawrot. It's his baby.)
MORT 11
HB 2399
Unread 25-08-2007, 01:30
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Air Cannon
I strongly suggest that you remake the barrel out of ABS plastic. Unless you have a burgoiuse amount, it should be pretty cheap (I got 5 feet of 2 inch dia ABS plastic for about 6$).
Even though the PVC will not be subjected to pressures over 60 (probably) for more than one second at most, if PVC fails it will shatter, whereas ABS will split or crack.
So, in terms of safety, Cracking > Shrapnel.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 25-08-2007, 04:20
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Air Cannon
Believe it or not, simply painting the cannon very nicely can be enough to convince people of its safety, if you are having trouble with that. People are easily swayed by appearance.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 25-08-2007, 10:06
Pat Arnold's Avatar
Pat Arnold Pat Arnold is offline
I think I over-think things...
FRC #1557 (12 Volt Bolt)
Pat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond repute
Re: Air Cannon
MARS Team 1523 created a t-shirt launcher over the summer too and has also run into school approval issues. Initially it was approved for use as long as it was mounted to a robot. Now the high school will not allow the "launcher's" use without team liability insurance. (We've found that calling it a "launcher" rather than "shooter" or "air canon" garners greater support. The earlier post about painting it is also true)
As far as safety, we discussed the design with an ME, EE, & PhD Chemist. (MARS used heavy wall schedule 40 PVC (whole thing) and fill the launcher to 80 psi.) Here were their thoughts : Regarding PVC bursting, it is dependent on the pressure and size being used. Typically what will happen is a crack will occur and slowly propagate at lower pressures. At the pressures being used in our launcher, crack propagation causing more than a leak would probably only occur if a weakness was present (such as the PVC was poorly made - which could be said of any material being used) or if mistreated (pouring a solvent on it, using a sledge on it, etc.). Where care must occur is in the glue joints, which if not done properly could leak or, if very poorly done, come off rapidly.
With others in the CD community suggesting PVC explosion, shrapnel, etc, I'm curious if they still feel this is a concern with launchers built using designs similar to MARS (heavy wall schedule 40, 80 psi fill).
Unread 25-08-2007, 10:17
Otaku's Avatar
AKA: Michael Baker
Re: Air Cannon
I'd still see it as an issue. Since the chance for failure is always present (and mostly the damage is microscopic but at those pressures you will magnify the problems) and PVC does tend to react in the way it does, it would really be your best bet to switch to ABS plastic.
Search on YouTube for Potato Cannon explosions. You'll notice all of those ones are PVC. That's why I built mine out of ABS.
Unread 25-08-2007, 10:48
Pat Arnold's Avatar
Re: Air Cannon
I don't think a total rejection of heavy wall PVC is warrented. Schedule 40 is rated for 200 psi and that's a conservative number (probable factor safety of 2). Household water pressures can run 70 psi (think of all the pvc used without a problem, i.e. water exploding from pipes) and I know of businesses using PVC tubing for compressed air running 120 psi.
Unread 25-08-2007, 10:55
Otaku's Avatar
AKA: Michael Baker
Re: Air Cannon
You'll also notice that all proper usages for PVC are underground, and that's for a reason...
Unread 25-08-2007, 11:19
in between teams
AKA: Luke Van Oort
Re: Air Cannon
Probably because it weakens with long term exposure to UV light. A quick coat of paint should fix that right up. (assuming it is the correct type of paint, one that doesn't weaken the PVC)
Team 1219: 2009 - Mentor
Unread 25-08-2007, 12:05
artdutra04's Avatar
Re: Air Cannon
It's actually against OSHA guidelines to use PVC for any kind of (non-buried) compressed gas use.
And easier way to think of the PVC vs. non PVC debate for air cannons is to compare acrylic to Lexan. We all know that acrylic may work for many uses on our robots, but we one needs to baby it in order to prevent it from cracking and shattering. If they used Lexan on the other hand, they don't have to worry as much about catastrophic shattering.
Art Dutra IV
世上无难事,只怕有心人.
Unread 25-08-2007, 12:22
Schnabel's Avatar
AKA: Eric Schnabel
FRC #0469
Re: Air Cannon
I win! XD
Unread 25-08-2007, 12:26
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Air Cannon
We're using a freon tank on our robot now. We used a PVC tank for over 3 years and never had trouble with it, but the team, including myself, were waiting on it to blow like a bomb anytime. Since this robot's main purpose is to demonstrate around people (most of the time little children) we changed the tank to metal with a blowout hole in case something goes catastrophically wrong. We are still using PVC for the shooter, and regular flexible hose for delivering the air, but all the pressure is behind the valve and really never on the cannon. We've also limited the amount of time that the valve can remain on for. I think its like 1/10 of a second or something so it uses less air, and also reduces the chances for something to go wrong. I think we will limit the pressure to 100PSI even though the tank can handle 300PSI. I'm not sure how much pressure our sprinkler valve can handle, and I don't want to find out either . With 60PSI I can shoot a t-shirt over 300 feet over a tree with with a 1/10 of a second shoot. Here are some pictures of our setup:
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Optimizing Air Cannon Range Matt H. Pneumatics 34 14-09-2008 20:11
pic: Toltech Air Cannon Prototype Andrew Schuetze Extra Discussion 2 29-05-2007 15:29
air cannon Evil Asian General Forum 10 15-03-2007 10:31
pic: air cannon cjreyda Extra Discussion 6 09-11-2006 12:05
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
