Go to Post Introverts can be good leaders too, we just lead differently. - Ari423 [more]
Unread 07-08-2007, 18:20
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: pneumatic potato gun i made
One precaution I will give you is that we have been building many air cannons over the years and every time we used pvc because of the cost for supplies and every time we got screwed over. Basically you have to treat it like glass because it will crack slowly with the pressure built up inside and will being put down to the point that it can't be used anymore. You may want to consider using something else.
Originally Posted by Tytus Gerrish View Post
90psi is nothing for a hand held gun i typically use co2 at about 850Psi. even with compressed air i go up around 250psi.
Just remember, the TechnoKats built a cannon this year and we can shoot into the crowd ~70+ ft. away at 50 psi.
I win! XD
Unread 08-08-2007, 11:40
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
ok, I tried hot gluing a straw to the other end of the valve and i can shoot mini pellets like 50 feet now.
the pellets are about the size of mechanical pencil erasers. I think i will get a smaller tube ~ .5 in. in diameter and launch baby carrots
Unread 18-08-2007, 23:08
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
take all your questions to www.spudfiles.com
if they cant help you, no one can
Unread 19-08-2007, 09:49
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Inline sprinkler valve is the answer for quick dumping of the tank. They work magic. We purchased plans from http://www.americanaircannons.com/plans.html for building a t-shirt launcher (yes its called a "launcher", not gun, shooter, or cannon, the school doesn't like that). The main bit of the project is a 3/4" or 1" in-line sprinkler valve, which has a manual control on the back and the solenoid (which is 24V AC) oddly works with 12V DC off of a spike.
Anyway, here is ours, attached to our 2005 rookie bot:
Unread 19-08-2007, 21:51
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
It may just react quicker to a higher voltage.
-John
Unread 25-08-2007, 10:27
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
For a Pneumatic gun (Which I don't have much experience with), you're going to want larger/more air tanks (plumb them together in a chain or such) and a sprinkler valve to release the pressure quickly.
Now, if you want help with a combustion potato cannon (check the legality first), then feel free to ask me as I've built two, a 3ft and a 7ft cannon.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 26-08-2007, 02:05
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
You don't want the tanks in a 'chain' you want them in parallel. This has already been covered earlier in the thread.
-John
Unread 26-08-2007, 18:49
Otaku's Avatar
AKA: Michael Baker
-John
Ah. Well, as I stated, I don't have experience with pneumatic systems for potato launchers.
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
Potato guns Adama Chit-Chat 24 22-08-2006 13:16
Air gun length Max Brin Technical Discussion 9 16-01-2006 15:45
Couch Potato Anyone? TravisCarpenter Chit-Chat 6 05-09-2002 16:48
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
