Go to Post "The audience will be making three sounds this year: oos, aahs, and oh my God, watch out!" - nate234 [more]
Unread 25-08-2007, 20:28
CraigHickman
Posts: n/a
A Math Question: Buoyency
Here's an interesting question that I hope someone can help me with. I'm looking to make a floating light system, but the only batteries I have access to are FIRST batteries. They're a bit big.
So here's exactly what I'm looking for, and I'm hoping to learn some math along the way. I have exactly 15 pounds of electronics and batteries, and I need to know the volume of the container that I'd need in order to make this float. I'd rather do the math for this first, so I can build the container out of Lexan, rather than doing the guess and check type experiment. It would be floating in standard pool water (chlorinated fresh water), with not too much water disturbance.
So how might one go about finding this out?
Unread 25-08-2007, 20:49
AdamHeard's Avatar
Lead Mentor
Re: A Math Question: Buoyency
You just need to calculate the average density of the whole container to it's weight.... If the density is less than 1 Kg/L, it floats.
So, you could calculate the volume of some random boxes to guess and check, or you can work backwards knowing you need to offset 15 lbs.
Unread 25-08-2007, 21:15
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
easy enough.
A cubic foot of water is about 64 lbs. A battery is about 15 lbs.
Rough order of magnitude math cause I'm too lazy to do it right:
Lets say a battery weighs about the same as a fourth cubic foot of water.
Therefore if the battery is larger than a fourth cubic foot, it floats, if less than a fourth cubic foot, it sinks.
Archimedes principle.
Thanks Archy
Ed Barker
Unread 25-08-2007, 21:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This is why I like the metric system. For as much as your float masses, it will need to displace an equal or greater mass of water. 1 Kg of float = 1 Kg of water = 1 Liter = 1000 cubic centimeters. I don't even have to waste the brain power on remembering how many pounds a cubic foot of water weighs.
Unread 25-08-2007, 21:25
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Find out how much volume a pound of water takes up (Google, perhaps?), then build a container to the shape you want with 20 times the volume of a pound of water.
-Otaku
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 25-08-2007, 21:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
A one gallon engine is the Buick 231 cubic inch (3.8 liter) V6. This I can remember.
And a pint is a pound, the world 'round. This I can also remember
so you need to displace two gallons of water (462 cubic inches, which happens to be a 1960s Lincoln engine) to make a battery float (8 pints in a gallon, two gallons = 2 x 8 lbs/gal = 16 lbs), and you need to displace more than that for the rest of the weight of your system.
you do understand about cubic inches, I trust.....just multiply the height times the width times the length (assuming a rectangular box) and you get the volume in cubic inches of your box.
Unread 25-08-2007, 22:03
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Cool Re: A Math Question: Buoyency
You are a CAD master. Use it. Draw the 'boat' without making the air and parts inside of it. Just don't hollow it. That way you don't have to solve for the volume of the boat. You just draw it and set the density for water. Check the weight, make sure it is more then the weight of the battery and equipment.
This is the way of the true CAD master, young mathawan.
Unread 25-08-2007, 22:19
CraigHickman
Posts: n/a
Woah, you all rock! Thanks a ton, I've now got my dimensions all done for a lexan box I'll be making to float in my pool with some sweet lights (FRC green cathodes). The box will measure 14" long by 5" tall by 10" wide. This should be slightly less than twice the buoyancy that I need, which should also give me plenty of room to put in all the electronics. I'll probably upload some pictures once I finish building the thing.
Thanks for the help!
Unread 25-08-2007, 22:24
ebarker's Avatar
AKA: Ed Barker
You are a veritable plethora of information. It never dawned on me until now that this particular Lincoln engine was twice the size of the Buick and was a gallon versus 2. we've got our selves a regular click and clack contender.
I just did a little punching in the calc and did the volume of 8 cylinders of 4 in bore and 4 in stroke and got 400 cu. I just had to try that out. back in the day the 4x4 happened frequently enough, like in a John Deere Model 40.
Ed Barker
Unread 26-08-2007, 08:25
GaryVoshol's Avatar
Cogito ergo arbitro
Don't forget to add for "freeboard" in case there are any waves. Don't want to swamp your electrics.
(since 2004)
A question for math and science people FIRST JerseyKid Math and Science 9 05-05-2005 22:36
Tetra Math ZZII 527 General Forum 34 22-01-2005 14:13
A math haiku mtrawls Chit-Chat 0 11-03-2004 20:22
Math Hermione692 Chit-Chat 15 21-02-2003 10:47
Math Help!!! Leon Machado IV Chit-Chat 7 16-11-2001 19:38
