Go to Post Then use Newton's handy-dandy 2nd law (Force = mass*acceleration) to solve... - Chris Hibner [more]
Unread 31-08-2007, 15:49
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: FRC294 Prototype base
Thats a really nice design you got there with a pretty beastly transmission system!! nice and low clearance too. I like to see that! *grins*
Unread 31-08-2007, 21:16
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
Have you used Team 33's design before?
In 2005 we used a modified Team 33 style 4 speed transmission. Aluminum side plates instead of Delrin and oilite bearings for the sliding members. We also used 2 CIM motors per transmission through some custom gearing and added additional reduction for a top speed of around 12 - 13 FPS in high. The transmission shifted perfectly every time and it was really neat to hear it constantly shift. It served us very well that year but we did have a problem with it. The shifting gears were prone to heavy wear on our machine. All of the hard shifting caused the teeth of the gears to elongate and become pointed as well as show extra signs of wear where the gears jam into each other during each shift. At Las Vegas, I showed a set to Andy Baker, and he mentioned that everything looked like it was constructed right (proper welds and all, but that he had not seen this problem before). We ran through 5 sets of cluster gears before the season ended (2 regionals and championships).
Now I can't say that this will happen to your team since we did modify the design, but we finally resorted to case hardening all the gears with Kasenit and a small furnace before we got acceptable wear resistance.
Should you also have this problem, consider case hardening the gears. We still use the robot for demos and the gears look fine.
As a suggestion, if you automate the gearbox, consider locking out 2nd gear. With 4 CIMS, the robot stays in 2nd for only a fraction of a second and almost immediately shifts into 3rd. We played with all sorts of rpm shift points, but eventually we just locked out 2nd making it a 3 speed and the robot worked much more smoothly. Of course we could manually put it into 2nd if we wanted to.
The Team 33 design served us very well in 2005 and is about the coolest to hear operate. Were glad we made it, but frankly we don't use that design anymore since it is much easier to buy AndyMarks solution and modify them for our use.
Anyway, I thought I'd share our experiece with the 4 speed design in case you haven't tried it before.
Unread 07-09-2007, 08:28
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Looks good, we had a design like this two years ago, we only had one problem, and let me suggest that you try to avoid this.... The wheels can't be too thick or too thin, but if they are too thin, you will have bad traction, too thick and you can't turn, so if its possible to incorporate into your design having thicker wheels in the middle of the outside two, this will give you good average steering, and there will be plenty of traction so you won't get bullied around.... Just like you, my team has been working for the last 3 years on trying to make a design that teams can't "pick a fight" with. So far, we have had some alright success, but still haven’t achieved victory, this year we have started already brainstorming ideas, comparing and contrasting positives and negatives of all the designs, and we think we have finally found what we were looking for.... are drive train is codenamed RAM and so far, it is pretty impressive from a cad standpoint. I will be posting pictures on CD soon, (when i get them) and you will be able to judge for yourself what you think of it. We all think that its pretty cool, but the competition will be the judge of that. I just want to say, that this is some amazing CAD work, and I hope that this works out for you, just make sure that you have enough traction to handle those gear boxes, or you will regret not doing it (like we did).
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 07-09-2007, 13:55
AdamHeard's Avatar
Lead Mentor
We were fine traction wise with 5/8" tread, we're running 1" now so it doesn't wear out as fast; either way, it's the same amount of traction. There's no need to run thickner center wheels, and for turning we have a lowered center.
For the 4-speed we are well past traction liminted in 1st and 2nd gear, 3rd and 4th aren't but we won't be pushing in those. If we have the FPs to spare then even 3rd will be traction limited. Most likely for the season we will run AM Gen3 shifters, we just wanted something cool to play with.
Unread 07-09-2007, 14:27
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
If you're traction-limited in both 1st and 2nd gear, why not eliminate 1st altogether? What benefit does it provide?
--Madison--
...down at the Ozdust!
Unread 07-09-2007, 15:06
AdamHeard's Avatar
Lead Mentor
We'll probably lock out 2nd gear in code....
you got to cut us some slack on the practicality ; We know 4 speeds is overkill, but we figured since we can just bolt on AndyMarks during the season, why not try something cool now? It's the offseason, time to try cool stuff.... And in all honesty, who hasn't wanted to build a 4-speed? We all know they're impractical for most games, but that doesn't take away from how cool they are.
Unread 07-09-2007, 15:17
Madison's Avatar
FRC #0488 (Xbot)
Now is the best time to experiment for many teams. We're also focusing a bit on some experimentation this Fall, of course.
I am not too familiar with 33's design for a transmission, so I thought it might be easier, faster and more reliable if you were to eliminate a redundant gear from its design. That said, it may also be more work and more time to make changes to it than not.
I have to be all about practicality because the Fall is the time when the mentors and I get to play around and introduce new ideas to our students, but at the same time, we're spending a lot of money doing so. I need to be able to justify the expense now with tangible benefits later. I can't spend $1000 of the team's money on something that we couldn't possibly use or build in a six-week crunch, y'know?
--Madison--
Unread 07-09-2007, 15:22
AdamHeard's Avatar
Lead Mentor
We have a two speed variant of team 33's that was the same cost in materials to build, so once again we went for cool; both were cheaper than buying AMs though. There is no sense in making it a 3-speed, it is two 2-speeds in series now. If we gave them inverse ratios we could have [AA,AB, BA, BB] (best way to visualize it i geuss) but AB and BA would be the same ratio, so we just made it 4.
these are being built for about the cost of a single AM shifter, so that's not too bad. Also, we have a lot of excess stock/hardware that could be used during the season now.
pic: Entire base Redo91 Robot Showcase 4 17-02-2007 12:24
pic: "Driveable Base" Cody Carey Extra Discussion 6 27-01-2007 23:29
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
pic: Rolling Base CD47-Bot Robot Showcase 7 06-02-2004 01:29
pic: 350 prototype CD47-Bot Robot Showcase 10 05-02-2004 13:23
