Go to Post The Scouting Award exists. It's called "Championship Winner". - Chris is me [more]
Unread 03-09-2007, 13:55
AdamHeard's Avatar
Lead Mentor
Re: Can the robot read a text file?
Originally Posted by bear24rw View Post
Um not directly, i guess theoretically you could store a file in eeprom and parse it from there or you could get somthing like (http://www.sparkfun.com/commerce/pro...oducts_id=7955) where you could put a .txt file on a SD card and read it from the RC.. if your looking for like autonomous scripting there is a way to do that too using an array of commands, it know it was popular in 2005 but i dont know where to find a link to it now..
kevinwatson.org has the code w/ autonomous scripting.
Also, CyDrive; It seems like you have something you want to do, why not tell us what you're trying to accomplish and we can reccomend the best way to do that within what the Robot controller can do.
Unread 03-09-2007, 14:02
Billfred's Avatar
Billfred Billfred is offline
Right person, wrong URL:
http://kevin.org/frc/
Unread 03-09-2007, 14:06
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
My idea is to create a program that almost any team can use to create an autonomous mode in under 2 minutes. Of course they would have to pre-configure the software with certain variables. Though i think it would be a great idea. I can write all the code i just need to know really how to deliver it to the robot without constantly having to do a re-compile. I believe an upload and reading of a text file would be much better.
Unread 03-09-2007, 14:29
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Actually this idea has been mentioned here before i know one kid ( i think he has a thread a couple down from yours) that is trying to use a game boy to kinda like what your talking about and if you do a search for USB or mass storage or SD card in the programming forum you will find a thread discussing exactly what your trying to accomplish
Unread 03-09-2007, 14:37
CyDrive's Avatar
Yes I was reading his thread and i thought it was quite interesting and the idea is not my own by any means. Actually it is an accumulation of ideas that i thought would be useful. Imagine on screen of your computer is a picture of the playing field from a top down view of the playing field you just click to place a dot. You can edit the actions your robot does when it reaches that spot or a many multiple things. Though what other people have tried to accomplish isn't very all-around friendly. They are all good ideas but i think it would be easier to use if you just had to upload say a text file with equipment you already have and you already understand. I also think it will make integration with any robot easier.
Unread 03-09-2007, 14:44
AdamHeard's Avatar
Lead Mentor
Talk to team 40 about their 2006 autonomous.
they had an app on a pocket pc in which you literally drew the autonomous path of the robot and the robot did it. Very impressive. We went to the practice field with them (we were together in the next match) and they watched our autonomous. Right away, they made the perfect custom autonomous to go with ours. Best implementation of autonomous scripting I have ever seen.
Unread 03-09-2007, 14:52
CyDrive's Avatar
I heard about that i heard it was done in Java. It sounded really cool. I will see if they will tell me anything.
Unread 03-09-2007, 15:23
AdamHeard's Avatar
Lead Mentor
The pocket pc side was done in Java. From there I don't know what they did. It could've generated scripting for something like Kevin Watson's that needed to be copied and pasted. Or, more ideally they probably had the SD card plug into something on the robot like thunderchickens has (or at least crosstheroad electronics).
Unread 03-09-2007, 15:29
CyDrive's Avatar
My theory is actually quite simple write directly to the EEPROM from my laptop with a custom program. Then use a custom scripting engine in the autonomous section. This will give me the 2 things i want. Ease of use and a fast way to create new autonomous modes.
Unread 04-09-2007, 18:31
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Why not do everything on the RC? You could provide a terminal interface like:
1) Display command list (list number)
2) Set current command list (list number)
3) Delete command (command number)
4) Insert command (insertion point)
5) Modify command (command number)
6) ...
Commands could be something like:
1) Drive Arc (arc parameters)
2) Drive straight (distance)
3) Turn in place (radians)
4) Set arm position (3-d position)
5) Catch fire
6) Inflate flotation device
7) End command list
8) ...
The bells and whistles camera code might give you some ideas.
-Kevin
Kevin Watson
http://kevin.org
Unread 03-09-2007, 15:31
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
I am not familiar with any flash memory reader for FRC robots. Can you provide a URL?
Unread 03-09-2007, 15:40
AdamHeard's Avatar
Lead Mentor
http://www.crosstheroadelectronics.c...cken%20AID.htm
I know it's not for sale by them yet.... but it is something that is possible, and I've heard of teams doing it before....
Unread 03-09-2007, 20:20
Do you know what teams have done it? I know people who have implemented reading from SD cards on PICs before, but not on FIRST robots, and I would love to find out how their procedure works.
Unread 04-09-2007, 01:18
If I remember correctly, SD/MMC cards run on an SPI connection. The IFI RC is using SPI on the user processor for something else.
This could be fixed by using an auxiliary PIC (although I would prefer an AVR.. woo GCC!), connecting the card via SPI, and using a serial connection between the aux board and the IFI controller. Also, I suppose if you wanted to get really fancy, you could emulate SPI by bit banging through the available i/o.
Can the FRC board read resistance? brennerator Technical Discussion 1 13-01-2007 22:25
I can read this....can you? Wayne Doenges Chit-Chat 2 22-03-2006 14:49
Can we assign alternate text for [img] and/or [img2] tags? Greg Ross CD Forum Support 2 01-11-2005 14:51
"Read the rules!" ...can it be said enough? generalbrando Rules/Strategy 14 08-01-2005 08:39
Help - Can you rotate an .avi file?? Elgin Clock IT / Communications 2 11-02-2004 00:56
