Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 05-09-2007, 13:09
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Re: Help on calc 3 problem would be incredibly appreciated...
Originally Posted by Kevin Sevcik View Post
Joe,
Do you know what form the expected answer should take? If it's simply looking for the ratio of the magnitude of OA to the projection, then that's pretty easy and Jack's advice applies.
If they're expecting you to calculate an actual load on OA, then that's a little trickier. In that case it turns into a system of 3 equations. On that track, the idea is that the loads on OA, OB, and OC add up to your load, but in the opposite direction. So FOA + FOB + FOC = (0,0,1000). The trick there is, again, to nomalize (turn into a unit vector) OA, OB, OC. Then you can multiply those unit vectors by a magnitude and end up with a system of 3 equations.
All I know is that they want the magnitude of the projection of OA onto the positive z axis... I dont think they want the load. So I am assuming that they want how much OA is pulling up on the Z axis. In other words, what part does it have in the system of 3 cables since it isnt a single cable pulling up on the z axis.
The exact question from the book is in quotes in the original post... admittingly it is pretty inspecific.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 05-09-2007, 13:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
In that case, I suspect you're looking at my second paragraph of hints, then.
Unread 06-09-2007, 00:07
AKA: Joeseph Smith
FRC #0066
Well... here's what I got so far:
I pretty much focused on OA... I did normalize the vector equation to get
[2/sqrt(21)] i + [1/sqrt(21)] j + [4/sqrt(21] k *This is after simplification, the magnitude of OA is 5sqrt(21)*
Realizing this will create ratios of force, and that the magnitude of the normal equation is 1, I then put this through the projection formula:
projv u = (u.v/||v||^2)v
Letting u = OA and v = the 1000kg vector... the x and y components logically no longer matter and its projection comes out to be
(4sqrt(21))/21 k
Then finding the magnitude of that projection resulted in:
16/21
And that is how the cookie crumbled for me... does that seem right???
I do like to learn different routes of logic, and vector math in calc 3 has definitely introduced me to that... so I really do appreciate the hints and everything. Helps me out a lot.
_joe
Update: thinking about it... the 16/21 had to be its portion of the load... so the actual load bearing capacity i came up with was ~762... but i still dont know if its right...
Joeseph P. Smith
jpthesmithe.com
Unread 06-09-2007, 21:20
Joe,
Why don't you sanity check the answer you got there? Apply the same procedure to OB and OC and see if your answers add up to 1000. If they don't... well then you're barking up the wrong tree.
Bias Calc DustinB_3 Programming 2 27-01-2007 23:04
not robotics, but help would be appreciated pryoplasm Electrical 26 02-06-2004 07:14
Would agreements help YOUR team? Alex1072 General Forum 23 24-03-2003 15:02
AP Calc Jeff Waegelin Chit-Chat 10 08-05-2002 21:08
