Go to Post The most important deisgn criteria is always performance in any of the parts / systems we design. But we do try to abide by the saying -- if it doesn't look good (right), it probably isn't good (right). - Adam Freeman [more]
Unread 06-09-2007, 11:59
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
Re: Can the robot read a text file?
Originally Posted by Tom Bottiglieri View Post
If I remember correctly, SD/MMC cards run on an SPI connection. The IFI RC is using SPI on the user processor for something else.
This could be fixed by using an auxiliary PIC (although I would prefer an AVR.. woo GCC!), connecting the card via SPI, and using a serial connection between the aux board and the IFI controller. Also, I suppose if you wanted to get really fancy, you could emulate SPI by bit banging through the available i/o.
I'm glad to see some interest in this topic, reading files from SD chips would be handy...
Last year I posted some information about using an SD module for holding autonomous scripting files. I used a module from DOSonChip, but I think it uses the same chip as the sparkfun model. I wrote some test code that runs on an SX28, but never tried it on an RC.
The code uses bit-banging on some port pins for SPI, and includes some simple file parsing examples. I intended to write some higher-level functions, but never got there.
All of the information is in multiple blog entries here.
Have fun,
Jim
Can the FRC board read resistance? brennerator Technical Discussion 1 13-01-2007 22:25
I can read this....can you? Wayne Doenges Chit-Chat 2 22-03-2006 14:49
Can we assign alternate text for [img] and/or [img2] tags? Greg Ross CD Forum Support 2 01-11-2005 14:51
"Read the rules!" ...can it be said enough? generalbrando Rules/Strategy 14 08-01-2005 08:39
Help - Can you rotate an .avi file?? Elgin Clock IT / Communications 2 11-02-2004 00:56
