Go to Post I would argue that you are not overdosed if you don't know the correct name of this year's game - KarenH [more]
Unread 03-09-2007, 15:31
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Can the robot read a text file?
The pocket pc side was done in Java. From there I don't know what they did. It could've generated scripting for something like Kevin Watson's that needed to be copied and pasted. Or, more ideally they probably had the SD card plug into something on the robot like thunderchickens has (or at least crosstheroad electronics).
I am not familiar with any flash memory reader for FRC robots. Can you provide a URL?
Unread 03-09-2007, 15:40
AdamHeard's Avatar
Lead Mentor
http://www.crosstheroadelectronics.c...cken%20AID.htm
I know it's not for sale by them yet.... but it is something that is possible, and I've heard of teams doing it before....
Unread 03-09-2007, 20:20
Do you know what teams have done it? I know people who have implemented reading from SD cards on PICs before, but not on FIRST robots, and I would love to find out how their procedure works.
Unread 04-09-2007, 01:18
If I remember correctly, SD/MMC cards run on an SPI connection. The IFI RC is using SPI on the user processor for something else.
This could be fixed by using an auxiliary PIC (although I would prefer an AVR.. woo GCC!), connecting the card via SPI, and using a serial connection between the aux board and the IFI controller. Also, I suppose if you wanted to get really fancy, you could emulate SPI by bit banging through the available i/o.
Unread 04-09-2007, 01:54
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
The module i linked to above from spark fun has SPI or TTL interface
Unread 04-09-2007, 18:31
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by CyDrive View Post
My theory is actually quite simple write directly to the EEPROM from my laptop with a custom program. Then use a custom scripting engine in the autonomous section. This will give me the 2 things i want. Ease of use and a fast way to create new autonomous modes.
Why not do everything on the RC? You could provide a terminal interface like:
1) Display command list (list number)
2) Set current command list (list number)
3) Delete command (command number)
4) Insert command (insertion point)
5) Modify command (command number)
6) ...
Commands could be something like:
1) Drive Arc (arc parameters)
2) Drive straight (distance)
3) Turn in place (radians)
4) Set arm position (3-d position)
5) Catch fire
6) Inflate flotation device
7) End command list
8) ...
The bells and whistles camera code might give you some ideas.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-09-2007, 11:59
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
I'm glad to see some interest in this topic, reading files from SD chips would be handy...
Last year I posted some information about using an SD module for holding autonomous scripting files. I used a module from DOSonChip, but I think it uses the same chip as the sparkfun model. I wrote some test code that runs on an SX28, but never tried it on an RC.
The code uses bit-banging on some port pins for SPI, and includes some simple file parsing examples. I intended to write some higher-level functions, but never got there.
All of the information is in multiple blog entries here.
Have fun,
Jim
Unread 07-09-2007, 15:43
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
I agree it is awesome to see people interested in this. I mean the use of these ideas can be very valuable.
Can the FRC board read resistance? brennerator Technical Discussion 1 13-01-2007 22:25
I can read this....can you? Wayne Doenges Chit-Chat 2 22-03-2006 14:49
Can we assign alternate text for [img] and/or [img2] tags? Greg Ross CD Forum Support 2 01-11-2005 14:51
"Read the rules!" ...can it be said enough? generalbrando Rules/Strategy 14 08-01-2005 08:39
Help - Can you rotate an .avi file?? Elgin Clock IT / Communications 2 11-02-2004 00:56
