Go to Post I always get a little stressed as arm operator, especially with Paul Copioli standing behind me screaming at me. - JohnnyB [more]
Unread 10-09-2007, 11:35
AdamHeard's Avatar
Lead Mentor
pic: 294 Prototype Base frame rail - almost done
Unread 10-09-2007, 11:39
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: pic: 294 Prototype Base frame rail - almost done
WOW! Those are huge! or so they look in the picture... how long are those? And are those milled out pockets going to be cut all the way through?
Is that 6061 (-T6)? 7075? ? Carbide cutter? What were your cut parameters to get that much aluminum chunked out in an hour? 1/2" End mill? Carbide? Chip tooth?
Ok.... so i'm feeling deprived... you got my blood going when i saw a big piece of aluminum. Hmmm i think i need to design something so i can make some parts... i havent crunched aluminum in a whole week... guess you can have withdrawls...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 10-09-2007, 13:22
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Looks like 6061 with a 1/2 in endmill judgeing by the size of the slots and finish of the alumnium. I could be totally wrong though. BCR you guys are great. Adam good luck with that chasis design it is quite the project and will be worth it in the long run. Looking good so far with those frame rails reminds me of a west coast version of a 233 chasis.
Good stuff,
Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Last edited by techtiger1 : 10-09-2007 at 13:22. Reason: I don't think a 1/2 mill exists lol
Unread 10-09-2007, 13:29
AdamHeard's Avatar
Lead Mentor
This is the first one cut so we tried a few different finishing patterns. the far end was cut all the way down with a 1" end mill, and then fileted with a 1/4" 4 flute end mill; We had to run really low ipm's though because it kept deflecting we kept loading the cutter with chips.
The near end turned out much nicer when we got a short and stubby 2-flute that we ran at 80 ipm (We can still run faster, we just wanted to test everything) and made a much nicer finish. We still used the 1" to rough it, but we didn't go all the way down, so the 1/4" still made the final pass.
Now, 1/4" seemed small to me.... but the instructor at the shop really, really knows his stuff; so I'll trust him .
As for the size, the finished product will be .375" x 5" x 37.5" for all the rails. Also, 233 was definitely an influence.
Thanks for the comments.
Unread 10-09-2007, 16:12
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
Yup Alumnium does that to endmills. I have a question Adam are you running coolant on that part becuase if you aren't you really need to. Also I hope you bumped down your step size with the 1/4in endmill as supposed to the 1 in. I can definitely see that 233 was an influence. Anyway just some thoughts on that reply post. Once again good luck.
-Drew
Unread 10-09-2007, 17:16
AdamHeard's Avatar
Lead Mentor
-Drew
Yeah, so much coolant is flowing that it still looks like a flat plate when cutting.
I'll admit, I did the CADing and not the MasterCAMing, but the guy that did it knows what he's doing so all the rates and such are reasonable. Thanks for the input.
In case anyone is wondering, the main influences are 233 (for the modules), 33 (for the transmission) and the "west coast drive" (4/22/60/254/968/1138) for the method of using angle that sits on the cross supports for bolt on super structures. The wheels were originally modeled after what 217 did in 2004, but are now more generic.
Unread 10-09-2007, 17:42
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Those look pretty sweet if you ask me!
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
pic: FRC294 Prototype base AdamHeard Extra Discussion 18 07-09-2007 15:22
pic: Team 294 Base AdamHeard Extra Discussion 9 21-04-2007 21:22
pic: FEA - Stress Analysis of Frame Rail kramarczyk Extra Discussion 5 01-02-2007 16:29
pic: Team 294 Wheel prototype AdamHeard Extra Discussion 5 09-10-2006 01:44
Pic: Team 20 almost done Ein Robot Showcase 2 16-02-2005 20:55
