Go to Post The biggest thing is you don't have to make your robot like another teams. Come up with something unique and go from there. RAISE THE BAR..... - camtunkpa [more]
Unread 11-09-2007, 10:15
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: Soldering questions
I'm trying to build antenna's for some 900MHz wifi cards.
Because I'm on a tight budget, I'm building the antenna's myself.
-Nathan
Nathan,
I hope you are doing the appropriate research on biquad antenna dimensioning and scaling to 900 Mhz. The ARRL Antenna Handbook is available at most libraries and has some useful info on antenna design and math. As you have seen in the articles, the authors had some trouble soldering to the outside of the N connector. They thought is was lack of heat, but likely it was the metal used to plate the connector. If you were to use standard hardware to mount the connector to the ground plane, (keep the hardware short please) you could solder a wire directly to the ground plane. To do this, use a longer piece of wire, bend the end (about 1/4-3/8") at 90 degrees and solder to the ground plane. Once soldered trim to the correct length for to set the antenna above the ground plane. At 900 MHz, a helical antenna may be an easier choice to construct and terminate.
Unread 11-09-2007, 21:10
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
Isn't Wifi 2.4/5 GHz? Are you making an antenna like this?
http://www.engadget.com/2005/11/15/h...-dish-antenna/
Unread 11-09-2007, 21:25
DonRotolo's Avatar
Back to humble
FRC #0832
Most of the previous advice is pretty good.
If I was to make that antenna, I'd first solder the double loop up with a small butane torch. Then use a soldering gun (the big ugly ones that should never go near a circuit board) to make the final connections to the connector.
Use 'helping hands' to hold stuff on place.
After assembly, use some silicone sealer to stabilize the joint mechanically.
The point about dimensional accuracy at 900 MHz is 3 times as important at 2.4 GHz; a fraction of a millimeter is important here. Unfortunately, you likely do not have the equipment to measure the results, so just be as careful to be as precise as you can.
By the way, if you want a directional WiFi antenna, I wrote an article on that, see ftp://ftp.tapr.org/psr/Autumn_85_2002.pdf on Page 8. Let me know if you ahve any questions on that.
Don
Unread 11-09-2007, 21:55
Nathan's Avatar
That's the kind of antenna I'm trying to build. I posted the link in my previous post but it got edited accidentally.
Thanks for the article Don! I'll make sure to read it. Any more advice would definitely be welcomed. I've been practicing on some spare wire I had laying around, I'll see if I can post a picture of on of them to make sure I'm doing it right.
Thanks,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
[TBA] TBA Presents... Soldering and Multimeter Tutorials Greg Marra General Forum 0 27-01-2007 20:15
Team 70 looking for missing soldering iron/station. Gene Williams General Forum 1 04-06-2006 20:08
Crimping/Soldering stevex Electrical 10 01-02-2005 08:32
check this out with soldering tiffany34990 Chit-Chat 1 16-08-2004 21:14
3 Questions!!! (2/12/04) Andy Grady General Forum 18 13-02-2004 14:16
