Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 14-09-2007, 03:45
Barchechath Barchechath is offline
AKA: Ben Barchechath
FRC #1580
Barchechath is an unknown quantity at this point
Send a message via ICQ to Barchechath Send a message via MSN to Barchechath
A Question about MPLAB
Hi !
I just got a new notebook PC that is running MS Vista (it it is matters the version is Home Premium), and I wonder if MPLAB IDE with C18 complier will work on vista? what about IFI Loader?
If the versions that I currently have from the last year doesn't support vista the new packaged software will support?
Thank you all,
Ben
Ben Barchechath
Unread 14-09-2007, 07:08
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Re: A Question about MPLAB
I just got a new notebook with vista on it and so far I havent had any problems. Mplab and the compiler installed and run ok. I havent tried editing or compiling any code yet because I just installed it and I dont have a usb to serial converter to load any code but I think it should run fine.
Unread 14-09-2007, 08:23
Gdeaver Gdeaver is offline
FRC #1640
Make sure your usb serial cable has a vista driver. My usb serial cable worked great under xp but is very flaky on my laptop with a vista driver. Looks like I'll have to buy a new one. Any body now of a good vista compatible usb serial cable?
Unread 14-09-2007, 15:33
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I've been running MPlab, C18, and EasyC, on Vista since April, and I've only had one issue.
EasyC wouldn't run unless it was run as administrator, but I have UAC disabled, so that isn't an issue.
Eric
Eric Haskins KC9JVH
Unread 14-09-2007, 16:24
FRC #1580
Thank you all for your help, when I will return to school from the "rosh hashana" holiday i am going to install it on my laptop PC.
Ben Barchechath
MPLAB Question Idaman323 Programming 4 30-01-2007 09:35
Question about transmitters Nick Fury Control System 3 05-04-2004 15:26
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Question about bumpers Randy_Ai Technical Discussion 2 23-01-2002 17:59
question about gyrochip wes16zeus Technical Discussion 3 13-11-2001 16:24
