Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Unread 14-09-2007, 21:33
Alex Cormier's Avatar
Alex Cormier Alex Cormier is online now
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Beverage chillin' machine.
Ok, heres the deal. I want to buy a 5/10 gallon water cooler. I don't want to ever buy ice again. So heres the challenge. Adapt a cooler to be able to plug into an outlet or ALSO be able to be powered by batteries for when im camping to keep the water cold.
I thought about a PC water coolign system but i talked to a friend and said that will not work. so i come to the CD community. what shall i do?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 15-09-2007, 11:50
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Beverage chillin' machine.
For power, set it up to operate on either 12 volts (then use a 110 power supply) or 110 volts (then use a 12 volt to 110 volt inverter).
For coolness, you can use a classical refrigeration system (but heavy, relatively fragile) of Peltier devices (limited capacity for cooling, especially freezing). Peltiers need heat sinks, cooling fans and have a limited temperature differential, possibly requiring stacked units for the temperatures you want.
Real water ice has a lot going for it. 10 pounds of it can take 288 ounces of liquid from 90 F down to 34 F in about an hour, and hold it there (in a commercial ice chest) for easily more than a day. The energy required to change phase from solid to liquid is considerable, so you are storing quite a bit of energy in that solid water - more than you might get out of a comparable weight of battery. The byproduct - water - is generally environmentally compatible.
Don
Unread 15-09-2007, 13:02
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Check out the Cooper Cooler.
I'm not sure about batteries though.
pic: me chillin in chicago its da PAT!!! Chit-Chat 3 22-02-2007 11:26
One machine? mzitz2k General Forum 19 03-03-2004 17:42
Brazilian Machine team_383 General Forum 1 22-01-2004 10:33
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
The only thing I'll miss from nationals: Frozen Carbonated Beverage asher Chit-Chat 22 30-04-2002 18:46
