#31
Re: Air Cannon
You can get a one inch solenoid-operated lawn sprinkler valve for under $15. They can be retrofit with a pneumatic release for manual operation or if you wanted to use a 12 volt valve from the KOP to operate the larger valve. I believe the standard lawn sprinkler valves are nominally 24 volt.
#32
Re: Air Cannon
What kind of ABS? The kind at our local Lowe's and Home Depot don't have pressure ratings? Is it just the generic one they have, or do we need a special type? Thanks!
#33
Re: Air Cannon
Schedule 40, should say "SCH40" on it. Schedule 80 if you want to, as well.
#34
Re: Air Cannon
An interesting article entitled "Kids, Do Try This at Home...We built a backyard cannon, and you can, too" appeared in the September 2007 issue of the Electrical Engineering magazine: Spectrum. Since so many of us enjoy this stuff, here's a link to the article online: http://www.spectrum.ieee.org/sep07/5483 Who wouldn't like to try some of the projects in the book cited. (Do pay careful attention to the safety issues it discusses before trying projects).
#35
Re: Air Cannon
#36
OK a air cannon how to make one quick and easy for about 50-75 USD you need
1. PVC pipe 2. Sprinkler valve 3. pneumatics tube 4. pneumatics fittings take the sprinkler valve top off and drill a hole in the top of it in all the other holes plug up air tight. then let it dry for at lease 10 to 20 min. Make your cannon as big as you want but make sure you can fit it on the sprinkler valve. make sure one end has a cap on it and leave one end open for your barrel. drill a small hole in the end of the end cap and put a pneumatic hose fitting on it and connect you hose to the end of your gun. then screw you barrel and the end that you put the hose on to the valve then put a air trigger on the hose comming from the top of your valve and pump it up and you are good to go have fun and be safe my buddys put a hole in there wall ![]() |
#37
Re: Air Cannon
Re: Air Cannon
Before this thread goes badly downhill like the other one, take a look at this:
http://www.chiefdelphi.com/forums/sh...ht=Matt+Howard Pay attention to the last page. ![]() |
#39
Re: Air Cannon
Hey all... I just wan to clear some stuff up about PVC, and there really isn't a better way to do that then to borrow Some words from a physics prof on a forum I frequent.
I'm not saying this is a good Idea, but people in my local offroading club have been using PVC as air tanks for portable systems for years. They mount these on bottoms of bumpers, roll cages, and other places where they are almost sure to get hit, and HARD. When I went to my first meeting and saw that, I remembered threads like this from when I frequented CD and asked if they'd ever had any blowouts or problems associated with this, and I was surprised to find that there had only been one... And it had happened when the guy forgot to put PVC cement on an end cap. Hows that for working in the real world? As a side note, the reason he says to test the system with liquid is because at pressure, the main difference between water and air is that air will explosively expand, and water won't. This means that if you have a leak and fill it with water, you won't have any sort of explosion, and if it holds up for five minutes at 200 psi, you know you won't have any problems below 100. Then again, It's pretty easy just to weld up a steel tank. |
#40
Re: Air Cannon
One of my good friends built a potato gun using PVC pipe as the air storage tank.
He was outside, with the tank pressurized and loaded, getting ready to launch one. He accidentally dropped it from a height of <3 feet...the tank exploded sending shards of PVC everywhere. One of those shards lodged itself into my friends forehead. He's ok, but he still has a harry potter like scar on his head. I'm not advocating the use or non-use of PVC as a tank here...but a story like this is definitely something to consider. Safety is always imporant, especially when working with pressurized vessels... |
#41
Re: Air Cannon
How far are you planning on shooting. If you don't have to shoot far, a PVC tank is fine because you don't need a lot of pressure. I attached some data I took from out air gun in the hopes it will ease some minds. Sorry it is in a documents. I couldn't make it fit any other way.
| Optimizing Air Cannon Range | Matt H. | Pneumatics | 34 | 14-09-2008 20:11 |
| pic: Toltech Air Cannon Prototype | Andrew Schuetze | Extra Discussion | 2 | 29-05-2007 15:29 |
| air cannon | Evil Asian | General Forum | 10 | 15-03-2007 10:31 |
| pic: air cannon | cjreyda | Extra Discussion | 6 | 09-11-2006 12:05 |
| Air Cannon | Michael223 | Technical Discussion | 13 | 14-06-2006 10:23 |
