Go to Post You don't want down time during build, eh? - dtengineering [more]
Unread 17-09-2007, 08:19
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
pic: Team 540 Air Cannon
Unread 17-09-2007, 14:24
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: pic: Team 540 Air Cannon
As I said in the other thread,
PVC = horribly unsafe. I would make it out of ABS if I were you.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 17-09-2007, 14:36
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I tried to cut the plastic out for use as a pressure vessel and just use it as a barrel... then use 1~2 of the craftsman pressure tanks instead, and manifold them together (if i use two) to increase the flow rate (they have a single 1/2" port)
However, i keep having trouble figuring out what kind of threads go with what.. NPT, NPTF, BSPT, I seem to go in circles and get confused.
Anybody out there good with pipe threads?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 17-09-2007, 17:33
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
This may have been addressed in another thread but couldn't you make the PVC safer by wrapping it in duct tape?Wouldn't give it more strength, but I would think it would prevent sharp shards of PVC from being sprayed everywhere in the case of rupture.
In any case, it's looking pretty good. We worked on an air cannon last year but haven't done any more with it. This year we're doing something else with the pneumatics.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 17-09-2007, 19:31
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
-q
Tanks usually (99.9%) come with NPT threads so NPT or NPTF fittings will work with them. FYI NPT & NPTF threads are interchangeable with use of PTFE tape.
Finding fittings that use BSPT threads in the US might be a problem.
Finally my apprenticeship years as a pipe fitter/ boiler operator come in handy here
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 22-12-2007, 03:53
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Though PVC creates shards, and ABS only ruptures (and does not explode), It has been thoroughly researched by people at the the SpudTech forums (now closed) and now the people at Spudfiles, and Sch 40 and Sch 80 PVC are a tried and tested way to create Pneumatic spudguns.
Duct tape tears easily and in our tests it was unable to stop an exploding PVC tank (we went to twice the rated maximum pressure, and slammed the tank with a remote activated 10lbs sledgehammer). In fact the shards we so quick when they exited through the duct tape that they also went through the plywood box the canon was in.
in a second test the gun was wrapped in an old pair of heavy duty Jeans. (the leg part), and when it exploded the jeans held the shrapnel.
At any case pneumatic spudguns are VERY DANGEROUS!
they can be fun but they should be treated even more carefully than a real gun, because a gun can only fire in a single direction, a spudgun might explode if handled the wrong way!!!
be careful!!!!!!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Air Cannon Rob2713g General Forum 40 27-05-2009 21:15
pic: Toltech Air Cannon Prototype Andrew Schuetze Extra Discussion 2 29-05-2007 15:29
air cannon Evil Asian General Forum 10 15-03-2007 10:31
pic: air cannon cjreyda Extra Discussion 6 09-11-2006 12:05
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
