Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 18-09-2007, 15:52
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
pic: AM Mecanum Chain Drive
Unread 18-09-2007, 15:53
luciaes luciaes is offline
AKA: shawn
FRC #0830 (rat pack)
luciaes is an unknown quantity at this point
Re: pic: AM Mecanum Chain Drive
nice, i wish i could convince my team to do a mecanum, unfortunately they wont budge
you lost the game
http://www.losethegame.com/
Team 830- The Rat Pack
Unread 18-09-2007, 21:49
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Well I will say if your going to do mechanum's this looks like an easy and efficient way to do it. Did you guys modify the am single speeds at all for weight or anything? Ohh I'd like to know how the rollers held up.
-Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 18-09-2007, 23:13
AdamHeard's Avatar
Lead Mentor
Is that an I beam as the frame?
Unread 19-09-2007, 01:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
What made you opt to link an AM single speed via chain rather than direct driving (or reducing) a Banebots transmission, which seems like it could be a cheaper, lighter, and more compact (in 2 of the 3 dimensions) solution. Don't really see the need to torque up a mecanum system, especially on a promobot.
Although I do very much like how well the system fits together (with the AM tucked in the frame and the CIM poking over the top), and I also like the use of channel (i-beam?) for the frame railing.
Unread 19-09-2007, 02:44
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
I got to see (and drive!) the base the night the team got it mostly put together, so I may be able to answer some of the questions...
-Drew
The transmissions weren't modified as far as I know; they just had longer bolts put through two of the holes to hold it on and together. The tensioner is just a nylon washer that is on the slot-mounted bolt. The chain is tensioned by tilting the transmissions back or forth.
Yep, fiberglass I beam. It has been used as the side rails for all of our robots to date; it's super strong and very easy to mount things to. (see here: http://www.chiefdelphi.com/media/photos/26813 )
I believe that we already had the AM singlespeeds on hand from previous experiments, so it was the cheaper route. Also, the chain reduction isn't for more torque; it's to make the bot drive slower.
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 12-04-2004 14:21
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
