[OCCRA]: extruded aluminum reposted
our team would like to use an 80/20 like extruded aluminum to hold the joysticks, I thought I saw some of this material last year. Is extruded aluminum legal?
thanks bs |
Re: [OCCRA]: extruded aluminum reposted
Thanks for re-posting.
Aluminum for the most part is extruded in the fabrication process. What you are referring to may be the pre-made extrusions that are often sold to make a frame or structure easy to assemble. They have pre drilled holes and fasten together with special clips. We do not allow this type of extrusions to be used in the robot construction because of cost and availability to all teams. However, you can use this material to mount your controls as it gives you no competitive advantage - just good looks. |
| [OCCRA]: extruded aluminum | bernieseaholm | OCCRA Q&A | 1 | 19-09-2007 21:04 |
| 80/20 Extruded Aluminum | MTA Gearheads | General Forum | 8 | 20-01-2007 19:10 |
| T-Slot extruded aluminum | blue_crew | Technical Discussion | 18 | 29-01-2006 13:05 |
| Using Extruded Aluminum to telescope. | LGuY | Technical Discussion | 21 | 07-02-2005 12:43 |
| Mini extruded aluminum | Ravi U | Technical Discussion | 7 | 17-01-2004 02:12 |
