Go to Post Just wondering what types of food you have been living off of while working on your robot? Our team has had pizza almost 3-4 times a week or more. Just wondering. SGS DRAGONS - sgsdragons [more]
  #31   Spotlight this post!
Unread 18-09-2007, 08:39
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
Re: Gearbox -physics related question
so whats this mean in a nutshell , im kind of lost
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
  #32   Spotlight this post!
Unread 18-09-2007, 13:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
In a nutshell, what it means is that you're probably not going to gain the benefit you though you might, from lightening the rotating parts in a robot gearbox.
Originally Posted by sporno View Post
If i cheesed a couple of the gears in the AM , or KOP gearboxes , decreasing rotational inertia , and rotational mass , would that have any effect aside from just cutting weight?
would it actually put more power to the ground , and create less drive train power loss?
It would put a little bit more power to the ground as you are bringing the robot up to speed--that is, it would help you win a "drag race" against another robot. But it will not give you any more pushing power, because once it is up to speed (or when it is standing still) there is no more gain from the lightening.
The idea might be useful for an arm, though, as it will take less power to raise an arm that has less inertia. So, when you are doing arm design, keep the weight at the outer end to a minimum!
  #33   Spotlight this post!
Unread 20-09-2007, 13:00
sporno's Avatar
AKA: David
FRC #0540 (Talon)
The drag race is exactly what i was getting at , and the power power to the ground
lets say you were ramming another robot ( i know not legal)
but if you got up to speed quicker would that change the momentum that someone was hit with?
Was i sorta right about the first topic
  #34   Spotlight this post!
Unread 20-09-2007, 13:26
MrForbes's Avatar
AKA: Jim
Hmmmm.....I dont' know whether or not you would have more ramming energy with more speed and less flywheel inertia, or the other way around, or the same. Interesting question.
Let's say you have two robots, Robot A has normal unmodified gearboxes. Robot B has gearboxes with very lightweight gears in them, so they can "spin up" faster given the same motor torque as Robot A.
Robot B would win a drag race, that is it would accelerate more quickly. However, Robot A would win a "coasting" race, as that extra energy stored in the heavier rotating gears would keep it moving longer than Robot B, after you turn off power to the motors.
  #35   Spotlight this post!
Unread 21-09-2007, 09:15
sporno's Avatar
AKA: David
FRC #0540 (Talon)
well knowing this, someone can dial in their bots a bit more
  #36   Spotlight this post!
Unread 21-09-2007, 09:22
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I dont have Inventor, but has anyone taking the AM shifter gearboxes and seen how much you can remove from some of the gears. And then from this calculate the weight saving, any acceleration benefit and any weakness you creat in the gears by doing this?
  #37   Spotlight this post!
Unread 21-09-2007, 10:51
sporno's Avatar
AKA: David
FRC #0540 (Talon)
this past year my team cheesed our gear boxes , we cut off some weight , but we never calculated anything that this thread is about
  #38   Spotlight this post!
Unread 21-09-2007, 12:17
MrForbes's Avatar
AKA: Jim
This past year 1726 left the chassis and drivetrain heavy, and the robot never fell over (unlike the previous year)
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
Who can be a mentor? (Not FIRST rules related but a general life question) Elgin Clock General Forum 4 11-12-2006 18:01
Gearbox Mesh Question Matt Reiland Technical Discussion 7 28-03-2005 06:04
FP Gearbox question ChrisH Motors 0 12-02-2004 16:49
DHTML question, not related to the robot robot180 Website Design/Showcase 4 19-04-2003 21:26
