Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 14-09-2007, 08:49
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Question abut CMUCam2 Camera with VEX
Hello every one
I am a monitor for school young girls and boys, more than 40 days without success. I try to get the CMUCam2 Camera to work tracking and servoing
Please someone let me know how to do that, I get sum help from some friend's but the question that I am vary bad in electronics and programming.
I need if some one have experience can send me:
1. full information how to connect wire the camera using the VEX controller.
2. cod to make the camera find target green light. Cod using Eazy C.
This will help me to work with my team. Pleas I have no experience wit this I am mechanical engineering from the old school. But I wont to learn.
Yours
Mohamed - Israel
Unread 14-09-2007, 11:21
Re: Question abut CMUCam2 Camera with VEX
See if this helps you hookup the hardware.
http://www.chiefdelphi.com/forums/showpost.php?p=507128
What version of EasyC do you have?
Unread 16-09-2007, 14:19
yara92's Avatar
AKA: Mohamed
first of all thank you for reblay.
I have Version 2.7.0.2
Unread 16-09-2007, 16:20
That sounds like the easyC for FRC version that was delivered in the 2006 Kit?
I don't have that version handy to directly help and I don't remember that it was compatible with Vex.
I'd suggest posting for help in the easyC sub-forum.
Unread 18-09-2007, 14:45
yara92's Avatar
AKA: Mohamed
Hi Mark
the easyC version 1.1 I purchase from Israel
tanks any way
Unread 18-09-2007, 16:44
That version came before easyC was expanded to support the camera.
It's still possible, however, you'll need to depend on the code Kevin Watson wrote for the camera that I referenced in my other post.
It can either be imported into easyC or you can download MPLAB and use that with the compiler that easyC v1.1 came with.
Unread 19-09-2007, 11:23
yara92's Avatar
AKA: Mohamed
Hi Mark
I have the MPLAB Compiler from FRC 2007, I downlowd a file witch working between both controller FRC and VEX.
I will be glad if you can send me the cod.
Thanks
Yours
mohamed
Unread 22-09-2007, 08:19
yara92's Avatar
AKA: Mohamed
hi mark!
I have eazyC pro activate. My friend Jon team 236 helped me with hardware connection.
Can you help me to understand who to write cod to make the camera find target green light?
I am waiting for your answer if you have the time.
Mohamed team 1946
EDU-RC with camera and Vex Parts Prototype michael714 Robot Showcase 2 19-09-2007 12:15
Quation using CAMERA-CMU-2 with VEX yara92 Programming 3 08-08-2007 17:28
CMUCAM2 on a Vex Controler Kingofl337 Programming 0 23-01-2007 16:09
CMUCam2 GUI Tilt Question Idaman323 Programming 3 27-01-2006 02:01
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
