Go to Post Don't rely on the field staff to get every ball to work with your machine....engineer a robot that makes the change not matter. - PayneTrain [more]
Unread 22-09-2007, 20:24
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
wiring diagram
i need a wiring diagram for the robot controller. because one of our graduated seniors fried the board.
If it isn't broken, Fix it till it is ~ Baker
Unread 22-09-2007, 21:58
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: wiring diagram
What do you really need to know about wiring the controller? The power inputs go into the 12V terminals (remember polarity!) All the PWM cables should go into the ports that your program uses. If it's default, look in the manual (I think the Left and Right drives go into ports 3 and 4 of the PWM Output terminals), Radio Cable goes into the port that says radio. I'm sorry if I'm acting like I'm treating you like a baby, but I'm not sure exactly what you are asking, so I'm stating the obvious.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 22-09-2007, 22:04
Re: wiring diagram
ooooo was there mysterious blue smoke by any chance? hehehe
Unread 23-09-2007, 00:27
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: wiring diagram
If you're looking for a schematic of the RC, they dont exist.. at least not outside of the IFI staff...
Unread 23-09-2007, 00:44
Smaug's Avatar
Re: wiring diagram
darn thats what i was looking for cause the senior fried something on the board and it might be easer to find out what he fried by knowing what exactly how the controller works. thx for ur help every one.
Unread 23-09-2007, 01:03
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: wiring diagram
Here is a picture of the board inside the VeX controller. I expect the IFI FRC controller looks pretty much the same, just more so. Are you sure you can fix something like this? If so, first you probably need to test it and see what is still functional and what is not, and then see about replacing the non-functioning parts. However, you might be better off sending the board in to IFI for repair....which probably will cost less than replacing the whole thing if your repair attempt goes wrong.
This might be something your team should discuss?
Unread 01-10-2007, 07:29
Re: wiring diagram
Smaug,
There is lot packed inside that little box and much of it is covered in conformal coatings. IFI is pretty good about repairs though. Customer support is one of the best things about IFI. I would check with them and get it sent back for repairs.
Unread 01-10-2007, 21:39
Smaug's Avatar
Re: wiring diagram
ok thank you every one i was hoping it might be something i could fix because it is a pretty expensive bored.
2005 Wiring diagram Krazykid Electrical 1 30-01-2006 14:41
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
Free Wiring Diagram! Mike Alighieri Electrical 16 30-06-2003 14:31
Wiring Diagram Andrew Foster OCCRA 4 21-10-2001 19:04
