Go to Post Own your words. - Joe Johnson [more]
Unread 23-09-2007, 08:34
The_Wizard's Avatar
The_Wizard The_Wizard is offline
AKA: Modell
VRC #0039 (The_ZipTies)
The_Wizard is an unknown quantity at this point
Send a message via AIM to The_Wizard
Quad Quandary Strategies
Who already knows what their robot's going to be and how they're going to use it thats willing to share?
Unread 23-09-2007, 08:39
1902_Battery_SGT's Avatar
1902_Battery_SGT 1902_Battery_SGT is offline
100% charged 100% of the time
AKA: Scott
FRC #1902 (Exploding Bacon)
1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all
Send a message via AIM to 1902_Battery_SGT
Re: Quad Quandary Stratigies
although i do not know what are team in going to to i have a strategy in mind. it would be for a robot to be able to pick up (maybe not fully) the two connected goals and carry those around while hording the smaller two into a side rail. then said robot would have control of all four goals making it darn near impossible to move.
Unread 23-09-2007, 14:44
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
I'm not on a team, so I may have some of my facts wrong (as in, some rules misinterpreted).
If I were on a team, I would build a robot that just hordes up as many of the rings as possible, and then dumps them all at the end of the match (or can u just put the robot w/ the rings into that area at the end?). I guess there are various flaws to this, but It's just my 2 cents.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 23-09-2007, 15:09
Billfred's Avatar
Billfred Billfred is offline
Having run through the video a few times, I believe a winning alliance will need two kinds of robots: one fast ringer capable of filling up the paired goals' posts as fast as possible, and a not-necessarily-as-fast enforcer capable of maintaining goal control. (An enforcer could be tasked with other things, such as descoring, but I'd mainly have it focus on keeping those goals safe.)
Of course, every team in FTC should be asking the magic question: "What would Simbotics do?" (Yes, this is a direct rip of Professor Grady's wisdom--but I don't think the comparison is unfounded.)
Unread 23-09-2007, 15:58
The_Wizard's Avatar
AKA: Modell
Re: Quad Quandary Strategies
Does anybody know if its legal to make a robot that does nothing but eat enemy rings? If so, that would be a good strategy to use if the metagame is centered around offensive robots.
Unread 23-09-2007, 17:00
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
Its against gracious professsionalism, but I cannot find a rule against this. Either way, unless you could manipulate the goals as well, you would be completely reliant on your alliance partner.
ROFL, true dat. Borrowing from Andy Grady, this year simbotics will score all ringers in autonomous and spraypaint the other alliance's rings to their own color just to stack more points. Speaking of stacking, their robot will stack all 3 goals and place them on their alliance area. They probably already finished building their robot, so we should probably hurry a bit.
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 23-09-2007, 17:17
AKA: Scott
Does any know if it's legal to lift the two connected goals off of the ground?... think of the traction.
Unread 23-09-2007, 17:28
fredliu168's Avatar
Legal, quite difficult though. The goals are probably many times heavier than your robot lolz.
In 2006
In 2007
Events:
Unread 23-09-2007, 17:57
The_Wizard's Avatar
AKA: Modell
Forget not that if we tip over any of the goals (even accedentally) we may get disqualified from the match.
Unread 23-09-2007, 18:21
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Sadly my team isn't doing FTC this year but still i was thinking about a design/stratagy in my many hours of spare time (pronouced when I lay awake at night lol). So how 'bout a robot that has an extendable arm with a simple claw on the end and that claw rotates up and down so it would have the ability to score any where. But this extendable arm could be used to pull the mobile goals toward you in autonomous mode. Think Rage(173?)'s 2007 robot.But, I think the Champion will be the team who replicates beatty's awsome 2002 robot and modifies it to grab all 3 of the goals ( 2 single and one half of the paired goal)
-Dustin Benedict
Unread 23-09-2007, 18:37
fredliu168's Avatar
The ability to grab all 3 goals is only 28 points (7X4). If a robot could score 6 out of 28 of their rings onto the double goals, they would beat out all 3 goals on the alliance quadrant.
However, if a robot could do both... hmmmmm
In 2006
In 2007
Events:
Unread 23-09-2007, 18:53
Billfred's Avatar
I dispute the allegations of un-GP behavior. If the game allows a given strategy (sucking up all the opposing rings), it is entirely within gracious professionalism for a team to make use of it.
Matter of fact, a strikingly similar strategy was seen on DaVinci in 2006 when 1148 employed a trap door on their robot to suck out an entire opposing auto feeder, removing that many scoring opportunities from the match for their opponents. With many robots shooting for just one source of balls, this was a devastating blow to a lot of teams. (I might add, for those relatively new to the party, that 1148 would win the whole show that year with Simbotics and Singapore SMART.)
It's no longer 2006, but the point remains: smart play within the rules is never against Gracious Professionalism. Heck, maybe you'll even score a few of those rings for your opponents (and given the RP system, it may well be in your interest to do so).
Unread 23-09-2007, 18:55
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
Lots of strategies were discussed at our kickoff event today when we could actually see what the playing field would look like. I doubt a robot would be capable of lifting the paired goals - you would have to be perfectly centered on the bar, raise it about 6 inches until it hit the crosspiece and then lift it and even then I don't think you could manage the weight load. Perhaps someone that was there today could elaborate? We had lots of fun thinking of different ways to play Quad Quandary. Field reset should be fairly quick once they get the hang of it. And setup and breakdown of the low-cost field took very little time.
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 23-09-2007, 19:25
The_Wizard's Avatar
AKA: Modell
If you have the field set up already, what is the mass of the rings?
Unread 23-09-2007, 19:27
AdamHeard's Avatar
Lead Mentor
IT wouldn't necessarily be a fast lift... but it can be done.
We built a winch last year with not very many parts that could lift and hold 15 pounds.
//FIRST// FTC 2007 Game Challenge Revealed - Quad Quandary! Mark McLeod FIRST Tech Challenge 3 23-09-2007 16:01
Defensive Strategies Goldeye Rules/Strategy 48 31-01-2006 19:16
The Quad @ BUZZ U. is now online! archiver 2000 0 23-06-2002 23:14
Best Strategies Rick Gibbs Regional Competitions 15 12-03-2002 09:23
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
