Go to Post *gasp* Robotics? bad for your health? I refuse to accept that as an answer. - Kiwi_queen [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Thread Tools Rating: Thread Rating: 36 votes, 5.00 average. Display Modes
Unread 24-09-2007, 00:18
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Changing Default Unit System
Does anyone know how to change the default unit system for newly created parts? Currently, my installation of Solidworks creates every new part in metric units, but my current project is all english units. So for every new part I create, I have to change the units in Tools --> Options --> Document Properties --> Units.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 24-09-2007, 00:37
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Changing Default Unit System
You need to change the document properties of the default part template files to use Imperial units.
It's typically named part.prtdot and is found in a path similar to this: C:\Program Files\SolidWorks\data\templates\Part.prtdot
Open that file as you would any other part, then take the following steps:
Select the Tools menu -> Choose Options -> Select right tab, "Document Properties" -> Select Units -> Change to IPS and make other changes as needed -> Save As and change file extension to Template (prtdot) -> Save back to original path.
You may be able to just save the template file you've opened rather than doing a "Save As," but I'm not about to try it and break my templates
--Madison--
...down at the Ozdust!
Unread 24-09-2007, 02:16
Engineering Mentor
Thanks! That worked great!
Unread 04-10-2009, 12:40
Hacivat2022 Hacivat2022 is offline
Hacivat2022 is an unknown quantity at this point
Thumbs up Re: Changing Default Unit System
Thank you very much
Unread 01-02-2010, 21:05
Engineering Mentor
While this fix worked great in 2007, I'm having trouble doing the same thing in Solidwork 2009-2010 edition. I can't find a template file anywhere on my computer like there was in the 2007-2008 version. Anyone know how to do this?
Unread 03-02-2010, 06:32
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Because of changes to the operating system, the templates are stored in documents and settings, all user, solidworks
This folder is a hidden folder and you will have to show it.
Also go to Tools, Options, System Options, File Locations. There you will see the default location for your templates. It might have to be changed.
Marie
Unread 28-02-2010, 16:09
TRASERDESIGN TRASERDESIGN is offline
TRASERDESIGN is an unknown quantity at this point
Marie
this might not always be true...
best option i feel is to, when opening a part or assembly, prt, asm file, change the file type to template, it usually finds the file and the directory.
From here, change all necessary areas, units, dimensions, callouts, etc. then save. this will save the start template over the original
also, once you enter SOLIDWORKS, if you arrange the icons/menus to the way you like them, exit out. this will save them and their locations for future use.
good luck ...
Help: IFI loader not communicating with control unit red_alert_13 Programming 9 20-01-2006 17:30
Anyone got CMU code for the EDU unit? Pixel Monster Robotics Education and Curriculum 0 21-02-2005 21:38
Receiver to control unit connection Bob16 Robotics Education and Curriculum 4 27-10-2004 09:20
Control System default proggie.. dense Programming 3 08-01-2002 10:20
::CHANGING SERVERS:: Brandon Martus General Forum 5 21-12-2001 10:33
