Go to Post That's wicked sweet (and I'm not even from New England). - Travis Hoffman [more]
Unread 25-09-2007, 17:12
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Opinions wanted: LabView-based controller?
Originally Posted by Adam Y. View Post
That is right. I don't remember how long it specifically takes to install LabView but there a significant amount of other programs that you install in a full installation. I also don't remember needing instructions though.
Labview can be run on all systems. In fact it would be a step up from running an emulator. It stems from the fact that LabView was originally designed on a Mac.
Umm...FIRST shipped the WINDOWS version of LabVIEW. AFAIK the other OS versions have to be ordered separately and are separate licenses. Those licenses are not cheap.
The problem is that you would be severely limiting your options with such a constraint. There are very little microcontrollers that have open source compilers. I'm all for using LabView if I can be shown it's a good choice for this application. I'm certainly convinced that it's an excellent choice for experimentation and data collection.
I am fairly convinced it is not a good choice for the reasons I outlined in the post you responded to.
It would be fun to experiment, but when all is said and done, I am much happier coding in C.
JBot
Aren't signatures a bit outdated?
Wanted: 2006 Robot Controller BradyP4 Control System 3 06-08-2006 21:13
Wanted: 2005 Robot Controller BSMFIRST Control System 0 01-03-2006 11:27
Human Arm based controller Andrew Schuetze Control System 5 09-10-2005 15:05
People's opinions.. pras870 General Forum 9 14-01-2004 23:53
2 v. 2 opinions P.J. Baker Off-Season Events 11 28-06-2001 13:24
