Go to Post Probably planning on milling the bumpers out of solid pool noodle stock, too. Ever wonder how they drill that hole down the middle of pool noodles? ;) - Bill_B [more]
Unread 26-09-2007, 03:21
SwartMumba SwartMumba is offline
SwartMumba is an unknown quantity at this point
help with large loop
Can someone please help me to correct my program. I have a variable, LargeNumber. The maximum value that LargeNumber will be is 320000000000, thus I have to declare LargeNumber as Int64. The problem is that the loop does not want to work with my variable, I think because it is declared as Int64. When I try to run the program I get an error message that says, "For Loop control variable must have ordinal type." The following is my Loop:
for Loop := 1 to LargeNumber do
begin
end;
{Since Loop is going to have the same value as LargeNumber, I also declared it as int64}
pic: Holomonic (Bottom View) with Large Omni-Directional Wheel Kit nonother Extra Discussion 9 16-05-2007 00:26
Help! Making Continuous Loop out of Plastic Sheet evolution Technical Discussion 7 19-02-2006 13:47
problem with using a loop CompMaster Programming 7 03-02-2006 16:44
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
