Go to Post why would someone do that? Go on the internet and tell lies? - MaGiC_PiKaChU [more]
Unread 26-09-2007, 03:21
SwartMumba SwartMumba is offline
SwartMumba is an unknown quantity at this point
help with large loop
Can someone please help me to correct my program. I have a variable, LargeNumber. The maximum value that LargeNumber will be is 320000000000, thus I have to declare LargeNumber as Int64. The problem is that the loop does not want to work with my variable, I think because it is declared as Int64. When I try to run the program I get an error message that says, "For Loop control variable must have ordinal type." The following is my Loop:
for Loop := 1 to LargeNumber do
begin
end;
{Since Loop is going to have the same value as LargeNumber, I also declared it as int64}
Unread 26-09-2007, 06:54
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: help with large loop
My first questions is, what language are you programming in?
Unread 26-09-2007, 07:14
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Use nested loops, if you have to.
Unread 26-09-2007, 08:22
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
If the compiler accepts LargeNumber as a variable but not as a loop counter, then you could consider using an infinite loop with LargeNumber as a variable that you increment on each pass. Exit the loop when LargeNumber is greater than or equal to the # of passes that you want.
Don't PANIC!
S. P. A. M.
Unread 26-09-2007, 09:21
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
A for loop is a higher level construct of a more primitive algorithm.
You can just implement the base algorithm instead.
The base algorithm has an initializer, a test & branch, the inner block, the incrementer and branch.
One assignment, one test, one arithmetic operator.
Enjoy
Ed Barker
Unread 26-09-2007, 20:43
Kelly Kelly is offline
FRC #1418
Kelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud of
With a for loop that large, it sounds like you're trying to create some sort of time delay. Assuming you're writing code for the robot controller, remember that your code is already running in a loop. To create a time delay write code like this:
int counter
while(true)//main loop
counter++;
if counter<largeNumber
do nothing
else
do stuff
If this is for a side project, disregard this comment entirely.
Unread 26-09-2007, 21:23
It looks like Pascal, so I'm guessing Delphi.
SwartMumba, this isn't a Delphi programming language forum. Look here for suggestions on better places to look for assistance.
Unread 26-09-2007, 23:08
Delphi. I thought this was a Delphi forum, www.chiefdelphi.com.
The value of LargeLoop varies, making life hard if you want to nest loops. There should be an easier way.
I tried that and the Loop crashes at 10000000000 Loops
Oh,okey..
pic: Holomonic (Bottom View) with Large Omni-Directional Wheel Kit nonother Extra Discussion 9 16-05-2007 00:26
Help! Making Continuous Loop out of Plastic Sheet evolution Technical Discussion 7 19-02-2006 13:47
problem with using a loop CompMaster Programming 7 03-02-2006 16:44
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
