Go to Post You don't need to be on a team to be involved with FIRST. - Koko Ed [more]
Go Back   Chief Delphi > Competition > Team Organization
Unread 28-09-2007, 14:07
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Band saw for cutting aluminum
As already stated, for heavy cuts (like a hacksaw) use a horizontal, for cutting patterns or intricately on thin stock use a vertical. The blade is the critical point, not the saw. Learn how to properly adjust a band saw - it is not intuitive - and it will serve you well.
As for getting a band saw, if budget isn't a huge issue, go for a name-brand tool in the 12-14 inch range. If budget is an issue, then a used tool can be had for a fraction of the new price, either saving several hundred dollars, or getting you a far superior machine for the same price.
A band saw made for wood CAN be used, but it's kind of like using a screwdriver as a chisel - it'll do, but it's really not the right way.
Don
Looking for a supplier of Keyed Aluminum Shaft ThorDiantral Technical Discussion 5 03-07-2007 19:20
Horizontal Band Saw sanddrag Technical Discussion 2 06-12-2006 22:52
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
Looking for aluminum wire archiver 2000 5 23-06-2002 23:48
