Re: Vex Controllers....Temp
What range of temps are you looking at? How much accuracy do you need. How fast will the system temp be changing (Delta T).
I'll bet it has to do with measuring the temperature of the water in the vicinity of the "serum"
http://www.h2orobots.org/fallmission.htm |
There is a temperature sensor on the KOP Gyro board from 06/07.
Hmm... maybe I'll add a "External Temperature" gauge to the OI pannel this year... -q |
I believe it could be used to offset the gyro's reading based on temp (because temp affects it)... At least that is what one mentor was telling me.
I dont have the datasheet on hand but that would make sense. If temperature affects the output of gyro it makes sense that they would tell you what the temperature was so that you could calculate the actual rotation.
#7
ps thank you for the great sujestions and this temp probe will be for undewaterand i want it to be as accurate as possible while keeping my the robot simple along with the code within it but i am open to any sujestions at this point have a good day every one!!! |
| Getting two Vex controllers to "talk" to each other | thefro526 | Programming | 1 | 28-05-2007 11:59 |
| Doubts about Gyro Temp | capenga | Programming | 1 | 31-01-2007 16:59 |
| Controllers? | joshR515 | Control System | 1 | 21-02-2006 16:06 |
| Need info on how to build temp. receiver and transmitter | archiver | 1999 | 5 | 23-06-2002 22:01 |
