Go to Post I don't need sleep, just more Mountain Dew. Oh, and a muffin. - hallk [more]
Unread 04-10-2007, 08:01
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: My teams electrical setup for 08...
It looks good! How close together are the components from each other? On our electronics board last year, the speed controllers and spikes were a half inch apart, and it was difficult to get the wires on without excessive bending of the wires.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 04-10-2007, 13:05
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
An addition to what Al said, you might want to buy a couple of circular housings for your connectors.
It will make it more organized and if put a male/female to the analog PWM ports and a female/mail to the speed controllers etc., it will make life easier if you have to replace a specific speed controller down the line, a spike, or even the brain. It will make your life much simpler.
Also I suggest having a few "back-to-back" speed controllers ready so that you just have to pop out two-three screws and pop them back in with the new speed controllers and it wills save you the hassle of removing a speed controller and adding one on. I suggest having at least 1 of those arrangements [two speed controllers] for both spikes and victors because you never know when you'll need it.
~Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 04-10-2007, 14:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This saved us much grief in Atlanta this year.
GitHub
Unread 04-10-2007, 20:28
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
This is definitely something you want to keep in mind. There needs to be a decent amount of space at the ends of the victors and spikes for the wires, especially depending on what is controlled and hence what gauge wire is used. We had some similar problems laying out our components in physical space - it's easy to forget about the wires and connectors when dealing with the neat little packages. And as squirrel said, putting the components together with their sides touching is a great way to save space - this is what we did when our failed pneumatically controlled arm had required 7 spikes to operate.
Unread 04-10-2007, 21:18
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
As the previous posters have said, think about the wiring a little bit more before committing to this design.
It might look good on paper, but just looking at your Spike relays, I'm seeing problems. If you're using the basic crimp on connectors to wire those, the connectors protrude from the connection point another centimeter or two, which will lead to some problems in the current design. You can solve this by rotating the relays all 90 degrees...but things will still be close.
A nice and compact design might look great on paper, but I know from experience what a mess wiring can make when you don't take it all into account. Nothing's worse for serviceability than a tangled mess of power and signal cables when you have to run them all in the same little space.
You might be able to make your current board layout work...but just make sure the components are facing the right way, so you can make the wires go where they need to without problems.
Unread 04-10-2007, 22:41
DonRotolo's Avatar
Back to humble
FRC #0832
As already said, beautiful drawing, but once you try to wire it, you'll see that it won't work.
Also, there is an advantage to having the Victors vertical, cooling works better.
The euro connector looks nice & neat, but if you ever had to remove the board, it takes a lot of time to actually undo all those screws. A circular or sub-D connector is fine for signals, but for power you need to use something larger, like the 20/30/45 Amp Anderson Powerpole series (They are all the same connector, the only difference is the size of wire they can hold).
It is good that the Victors are covered a little, as metal shavings and other debris are major failure causes. Keeping wires short helps with weight, more than you think. I don't see a fuse panel, but there's room on the top, or underneath the bottom. Don't be afraid to drill holes for wires, either.
Don
How to setup CNC for making dog gears sanddrag Technical Discussion 4 01-01-2005 23:21
Electrical Tips for Rookies Anne Shade Technical Discussion 15 03-12-2004 12:08
Quick disconnects for electrical gail OCCRA 1 25-10-2003 16:10
Electrical changes for 2003 Andy A. Electrical 3 05-01-2003 21:00
UTC Hartford and the Pits in 2001. The same setup for this year??? Elgin Clock Regional Competitions 3 01-11-2002 19:11
