Go to Post I think that's what they think you will think, therefore you are thinking what they want you to think. - Wetzel [more]
Unread 04-10-2007, 16:16
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
OI control box, LED questions
I have been planning on adding a custom control box to our teams controls this year, but I need some help with a few things.
First, is there a way to have an LED in the box correspond to an LED on the OI? For example- is there a way to make an LED on the light up with the switch 1 LED on the OI?
Second, is there a way to use the competition port instead of one of the port ports for the box? I would include the competition switches in with the box.
Thanks!
Team 2052- KnightKrawler
Mentor and volunteer
Unread 04-10-2007, 16:30
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: OI control box, LED questions
1) Yes, you can light up external LEDs.
2) No, you CANNOT use the competition port.
Check out http://www.thebluealliance.net/2006/...stom-controls/ for a PDF with a wiring guide and some other useful hints.
Unread 04-10-2007, 17:37
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
This is correct that you can't use the competition ports for control wiring in the competition. You must connect directly between the OI controller and the field wiring. However, I recommend building autonomous and disable switches into your OI panel with a cable that you plug into the competition port while practicing and testing the robot. Building these into the panel keeps them from getting lost.
Unread 04-10-2007, 17:38
AKA: Bryan
Seen the blue alliance link (tons of help).
HOW would I wire the LEDs for sw1/2/3? I saw the pwm ones, but what about switches?
I was planning on building the competition switches into the box anyways. I was asking about the port because I heard someone mention they had done it. I was doubtful, so that just confirms my suspicions. Thanks.
Unread 04-10-2007, 19:23
There are built in pull-up resistors in the OI. All you need to do is connect the correct end of the LED to the pin controlling its state and the other end to any of the ground pins. Do you know how to wire a DB15 connector for custom controls?
Unread 04-10-2007, 21:27
As you saw, the external LED drivers on the IFI operator interface only support the eight signals that correspond to the "PWM" and "Relay" lights. If you want feedback from limit switches, you'll just have to make the software control one of the LED signals you can use.
Unread 07-10-2007, 22:53
AKA: Bryan
Okay, I think I get it. I would have to use the relay lights on the OI for switch lights, instead of relay lights? Where in the coding do the pins for the relay lights get mapped to relay lights (or is it in the OI's code)?
Finally, is there a way to hook up an LED display (4 digit) to the OI? We were thinking that an LED display to display the pressure in the pneumatics would be a great feature. We would like to hook something like this up to the OI. Ignoring external power rules, could we make it work?
Unread 08-10-2007, 00:27
It's in the user_routines.c file, I think at the end of either process_data_from_master_uP() or Default_routine() (don't rely on my memory for proper spelling or capitalization of the function names).
The OI already has a 4-digit LED display. You can use the "user byte" feature to send an eight-bit integer to be shown on it.
We did exactly that for our 2004 robot. A "diagnostic select" switch let us choose among pneumatic pressure and feedback from the turret, elbow, and wrist position sensors. It turned out not to be very useful during competition, but it helped a lot for setting limits and presets when programming.
If you want to do something like that, using the dashboard port is probably the best way to do it. External power is not an issue for things connected to it, and you can send back six bytes of arbitrary data without restriction. You can also cheat and repurpose unused PWM channels as extra data bytes (though I think the value FF is forbidden, and gets sent as FE).
Unread 09-10-2007, 16:01
AKA: Bryan
I know theres already an LED screen on the OI, but we would like to keep that open, along with the user byte, if possible.
As for the light mappings in the code, I'm not talking about where it ells the light whether to turn on or off, I'm talking about where it says that pinX = relay1_green. I found where it sets the p1_x, y, switch, trig, and the other inputs, but I couldn't find the outputs.
Is there a guide out there for using the dashboard port for inputs/outputs?
Unread 09-10-2007, 16:43
Those pins are a hardware feature of the OI. There's no code associated with them, other than the code which turns the LEDs on or off. You can find the pinout in the OI reference guide that you can download here; look for the documentation of ports 1 and 3.
It's output only. The dashboard specification is included in the .zip file with the Dashboard Viewer program.
Unread 09-10-2007, 17:47
You can't have your cake and eat it too. The LED will only display whatever is set to the user byte, and while it is displaying that, none of the LED outputs will light up.
Unread 11-10-2007, 15:48
AKA: Bryan
I downloaded the available dashboard files from IFI, but saw no pin mapping, only a bit/byte list. Is there a pin-out list somewhere?
Unread 11-10-2007, 16:15
Again, you can find the pinout in the OI reference guide that you can download here.
Unread 12-10-2007, 18:02
AKA: Bryan
I'm looking for the dashboard port pinouts, that manual only has the port 1, port 2, port 3, and port 4 pinouts.
You originally told me to check the dashboard program's files, but those files only have bit/byte lists/references, no pin mappings.
Unread 13-10-2007, 00:20
I apologize for not understanding your question fully. I think what you want to know now is in the OI reference manual section "7. Dashboard Port" on page 12:
Connect the DASHBOARD port to the RS-232 serial port of a computer using a DB9 Male-Female Pin-to-Pin cable (maximum length 6 ft.).
pic: a control box CD47-Bot Extra Discussion 30 16-03-2004 00:08
Control Box Bling phrontist General Forum 4 08-02-2004 21:07
Custom Control Box D.Viddy Programming 3 15-02-2003 11:35
Box Control Tton General Forum 2 12-02-2003 23:38
control box archiver 2000 8 24-06-2002 00:20
