Go to Post Try to remember, FIRST is like life, it is about the journey not the destination. - rees2001 [more]
Unread 05-10-2007, 04:35
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Lightbulb Another electical setup idea from my team fo 08...
First of all, These are all student designs, we split them in groups and gave them a basic idea and told them to design something out of/around it. The images here are a different groups ideas from the last post.
and we are planning on using Anderson power poles and circular connectors for modular power and signal wires.
thank you
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 05-10-2007, 04:37
AKA: Cameron Dennis
Re: Another electical setup idea from my team fo 08...
Also, the students are learning inventor through this exercise, and these are completely student created.
www.frc1266.com
Unread 05-10-2007, 12:35
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
I may not be billfred, but i give this design my stamp of approval. If you can make that (with neat wiring) FIRST legal (which is not hard) then wow. You may want to look into making "cat plates" (see team 118's board from this past year. That will save even more weight, and will be an outstanding feature that will impress the judges.
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 05-10-2007, 13:56
DonRotolo's Avatar
Back to humble
FRC #0832
Thumbs up Re: Another electical setup idea from my team fo 08...
I like this design better than the other one I saw. Nicely laid out, accomodates wiring well and efficiently, allows for troubleshooting and repairs well enough.
Note that the space beneath the Clippard tanks is also available, if you approach from beneath the robot. Good place for the fuseboxes and other miscellania that doesn't need to be accessed often.
Don
Unread 05-10-2007, 19:14
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
i like it, but personally i'd rather make it a little bigger and have the victors on the inside of the lexan to be more protected
Unread 05-10-2007, 21:05
Billfred's Avatar
Billfred Billfred is offline
Given the options of putting some further protection around the box as pictured or moving everything inside (and then risking a close-quarters Victor surgery), I'll put some more protection around the outside.
My question deals more with material choices. I can't tell thicknesses of the materials, but was there any reason to choose them? Cost? Availability? More strength to tie into some other part of the robot?
Unread 05-10-2007, 23:14
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Like the above have said, my biggest worries is about the protection. Also with the previous model you showed us there was some modularity which meant you could remove parts and add them easily. With this it seems like it will be a bit harder. Also are your students considering weight? Weight is a BIG deal. Also what size have your previous years' bases been? For an average team, that idea should be okay, especially if you're using some sort of 6 wheel or tank drive. Good luck and I hope to be seeing more from your team!
~Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 06-10-2007, 00:26
AKA: Cameron Dennis
we were talking about using 1/8in polycarbonate with 1/4X1/4X3" aluminum pillars, everything will have tapped holes so all we would do is just screw into it, same with the victors so if we blow one its easily removable, me and the other mentors decided thats basically what we wanted to go with, but we were up to what ever idea the students came up with. the main reason for this was because we have all these just sitting around
www.frc1266.com
Unread 06-10-2007, 02:08
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
That's what I always say
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
I like this exercise, it gets the students thinking and working with inventor.
I'd lean more towards total space savings and not worrying about victor repair.
As long as I've been on 190, and quite a few years before that, we've never had a problem with our victors.
The problem with an electrical box of this type is that often there simply isn't room in the robot to have everything electrical (and pneumatic in this case) centralized. The current design (which is well done and a great thing to do if possible) requires a significant amount of space on the robot, and space is the second most precious commodity on a FIRST robot.
The first most precious commodity is weight, and we've found that unless your robot has several pneumatic cylinders firing often during the match, 4 accumulators is far more than necessary. Our robot this year, which had the two major systems pneumatically actuated, got away with a compressor and 2 accumulators.
All in all, excellent way to get the students involved, keep thinking.
On an unrelated note: If you can afford it (and find them), I highly recommend using nylon bolts for mounting electronics. The bolts are just fasteners, and weight is always at a premium. We used them with great success this past year.
WPI District 2017 Volunteer Coordinator.
I'm not here to help.
Unread 06-10-2007, 13:36
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
wow I really like that idea of having the reservoirs under all of the electronics.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 06-10-2007, 14:33
Well guys, I am liking this one a lot. The only thing missing is the terminal block for power distro and the dreaded orange light. I am guessing (and I mean guessing, I will find out when you do!) that the block will be back this year. I think that can be easily accomodated with a rotation of the small fuse panel and the large fuse panel. A little move and voila! you have space for the terminal block. Please note that this design really minimizes wire runs by keeping everything close together and centrally located for the fuse panels. Visualize the wire savings if all the components had the power input terminals on the top side of this design. It is almost an inspector's heaven as everything is open and in view. Even the Spike for the compressor is right at the compressor. Congratulations on a design that responds to robot needs, replacement worries and inspector desires.
Unread 06-10-2007, 14:42
dtengineering's Avatar
AKA: Jason Brett
Protecting the victors from having little bits of metal fall into them and short them out is important, but so is protecting the RC. During build last year (or was it two years ago, now... I forget) we had a small aluminum chip fall onto the RC and land in such a way that it shorted out a couple of unattached I/O pins on the RC. This led to all sorts of RC weirdness... thankfully no permanent damage... but since then I've figured that having a lid over everything is a big asset.
This is a great exercise, though... I might have to set a few of my students loose on a similar project just to get them thinking and practicing on inventor.
Jason
P.S. Yeah, I know... never drill or cut over the electronics... but those little chips get everywhere.
Unread 06-10-2007, 15:14
AKA: Cameron Dennis
we rarely have problems with chips, and almost never have any problems with victors tho we were throwing around the idea of a screen covering for the victors
www.frc1266.com
Unread 11-10-2007, 13:47
copperhead47's Avatar
copperhead47 copperhead47 is offline
AKA: Grant "gunner" T.
FRC #1647 (Lenape Regional Iron Devils)
Team Role: Electrical
copperhead47 is an unknown quantity at this point
Send a message via AIM to copperhead47
veeerrrry swanky i like it- we tried making a removable panel last year and that my friends, is the making of a purely superb modular design (i hope by anderson power-pole you mean mini andersons- which was some thing I've stumbled across over the summer)
CHEERS!
Bringing a member from another team to competition Jill1022 General Forum 26 05-05-2005 15:02
Another brilliant (?) idea from The Clock. - re: Birthdays. Elgin Clock CD Forum Support 10 04-10-2004 16:30
Another Great Idea from the Bowels of Tigerbolt FotoPlasma Chit-Chat 8 01-09-2002 00:26
Another Idea of Expanding the Nationals archiver 2001 2 24-06-2002 03:28
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
